I have a B7800 with a mid-mount 72" finishing mower. I believe the mower is from Kubota, but I'm nost sure as it came with the tractor when I bought it used. My problem is that it doesn't cut well, leaving streaks of grass only partially cut, especially when turning. I wonder if my problem is one of the following:
1) I removed and sharpened the blades a few weeks ago. I failed to notice the direction each blade was mounted and so, I remounted in a random way. Do the blades (three of them) need to be mounted in some particular orientation?
2) I am going too fast. I typically am in 2nd gear moving "slowly". I have tried 1st gear, running at the max of this gear.
3) I am running the tractor at too an RPM. I typically run it at 1700 RPM but I have tried 2000 RPM.
Any suggestions??
Any suggestions??
