Problem replacing the Driven Disc on Snapper Lawn Tractor
   / Problem replacing the Driven Disc on Snapper Lawn Tractor #1
Smithwicks51
Snapper YT12 Series 4
My disc needs to be replaced, but when I try to loosen the nuts that hold the plate on, the disc just spins. Does anyone know of a way to keep this from happening. I have tried several wooden shims. They just get pulled down between the rubber on the driven disc and the plate that the disc rides on. I have tried moving the gear shift lever to all positions. None of these stop the disc from rotating. I could use some help. With all the rain were having I will soon have to bale my grass for hay.
   / Problem replacing the Driven Disc on Snapper Lawn Tractor #2
IIRC, there is at least one hole in the driven disc that you can insert a screwdriver in to stop the rotation.
I just use two box-end wrenches, one to stop the rotation of the disc and the other one to loosen another nut.
There is a brake pad inside, but mine is so worn I don't think it will stop it from turning.
Thanks for the reply. In another forum I saw a tool that sells for $7.95 online, but shipping is also $7.95. I like your idea better. Had not thought of the screwdriver idea. Thanks for the reply.
2 MONITORS:  HP & SAMSUNG (A53843)
2 MONITORS: HP &...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2013 Chevy Silverado 2500 HD (A53473)
2013 Chevy...
2014 PETERBILT 386 DAY CAB (A54607)
2014 PETERBILT 386...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
