3-Point Hitch Problem maintaining Lift Link Adjustment
   / Problem maintaining Lift Link Adjustment #1
rjrhoades
Kubota L3400
When I adust the tilt link adjustment, AND lock the assembly with the locking nut, the assembly will move a LOT during normal brush hog use - allowing the right side of the mower to drop 3-4 inches in an hour of use. If I use a HUGE wrench (14") to really clamp the locking nut to the top of the adjusting cylinder it will stay - but this is a huge amount of force to have to deal with all the time. Does anyone else have this problem and what did they do to stop the creep? I don't need to adjust it that often so a hydraulic adjust isn't warranted. But it gets very annoying having to constantly adjust it under normal operations.
   / Problem maintaining Lift Link Adjustment #2
I fought the same problem. Surplus Center, Surplus Center - Hydraulics, Engines, Electrical and More, has one with a tee handle in the middle of the barrell and a locking dog on one end. I just ordered one. A friend said that was the way to go. As far as I know no one else has one that short. Kubota is unique on that. I had bought a longer one but it wouldn't go short enough for some adjustments. My dealer says "what's wrong with a factory approved assembly"? He doesn't have to do this stuff in the mud, snow, snd rain.
Ron
I can't find what you are talking about in the Surplus website - can you give an item #?
   / Problem maintaining Lift Link Adjustment #4
Make a turnbuckle lock. Use the loop on the side (or weld on a chain link) to tie to the clevis with a tight wire.
Bruce
   / Problem maintaining Lift Link Adjustment #5
The locking nut has always worked for me. But I do like the last method of fix. A quick and easy job with a peice of wire or something.
   / Problem maintaining Lift Link Adjustment #6
R J,
Page 130, item 1-3131, bottom of page, 18.95 + shipping
If they did not secure their catalog I would send you a copy, and if I could figure out to add attachments to this forum.
Mine will be here next week and I will post an opinion. Surplus Center is a great place to shop. Their Tech people are very helpful on the phone.
Ron
   / Problem maintaining Lift Link Adjustment #7
Is it possible this is a symptom of too much vibration, like maybe the PTO shaft is bent or out of balance, or a cross joint is badly worn?
Does the cylinder separate from the nut, or are both moving together? If they're moving together you could either use a locknut in place of the existing regular nut, or put a second nut on and jamb the two nuts together so they provide the resistance to turning. If the cylinder and nut are separating, then safety wiring would probably be the way to go.
R J,
Ron
So you use the toplink for the side arm link? I am confused.
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A52128)
2018 Dodge Ram...
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
2024 CATERPILLAR 299D3 SKID STEER (A51242)
2024 CATERPILLAR...
2022 ESTATE MOWER 6' FINISHING MOWER (A51243)
2022 ESTATE MOWER...
