problem locking the skid loader
   / problem locking the skid loader #1
Richard R.
Molino FL
2000 ford/ bushhog loader, 3203 john deere, 5035 mahindra ML130 FEL
I have a new 5035 with the ml 130 fel. I can not get the left side to lock down compleatly. It doesn't matter if I am trying to put the pallet forks or the bucket on when I push the left handle down all the way the pin does not seat compleatly. any suggestions. :confused:richard
   / problem locking the skid loader #2
There is a long bolt between the handle and the locking slide. In between the two, there is a square ended shaft that connects the two, which is held together by a long bolt with a nylock nut on one end. Check to see that this bolt is tight. I drilled mine out and put a heavier bolt in both of mine. The size bolt they had in there was like 5/16 and I went 3/8"... theirs probably was metric.. If you don't keep this bolt tight, you can round off the square connectors, like what yours is probably doing. I welded and fixed one of mine. Once you pull one apart, you will see what you are dealing with.... Good luck, Jerry... :)
   / problem locking the skid loader #3
I think the main problem is that when you go to hook something up, your skid lock are open with the handles in the UP postion. So when you are going forward to hook up, these handles are sticking out in front a little and if you run them into something in the process, it puts too much stress on the long bolt. This streches the bolt some, and allows the square shaft to slip a little over time. Once that happens, when you move the handle, you are actually not turning the square shaft enough. Once I went to 3/8", I have not had the problem.
thanks Jerry I will check that. allttough I have only connected them twice. and it has been like that since I took delivery. I have contated the dealer and he is checking on that problem and a hydrulic leak. I allways like to get advice from the forum.:thumbsup:
   / problem locking the skid loader #5
If/when you take it apart... you will see that you don't have to remove much stock to drill the whole thing out to 3/8"... Either that, or don't use the locking handles as bumpers... :)
jerry I took the tractor back to the dealer they found the tool carrier was twested. so they have ordered another. it's not something that's obvious just enouth so the left lock wont work. Richard
   / problem locking the skid loader #7
Cool... !!!! I use my QA quite a bit swapping between the bucket and the forks... Couldn't see owning a tractor without the QA on the FEL.... Have a great Labor Day...!!! Jerry..
2013 RAM 4500 (A50323)
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
FRONTIER  ROUND HAY BALE SPREADER (A52472)
FRONTIER ROUND...
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A52748)
New Lewis Brothers...
Kubota Salt-Spreader (A52384)
Kubota...
