Problem Back Blading With The 200CX loader On My JD 2520
   / Problem Back Blading With The 200CX loader On My JD 2520 #1
coollx
Bronze Member
Upstate NY
John Deere 2520
Need help determining why all of a sudden there is no hydraulic pressure when I try to back blade with the 200CX loader mounted on my JD 2520 tractor.
Bought the tractor new about 12 years ago and it has always worked fine. The hydraulic fluid is full and has been changed as recommended. The loader works fine when lifting, carrying, lowering and dumping the bucket with heavy weight in it.
With the tractor running and the bucket raised and tilted downward as if to lower it to back blade material, when the leading edge of the bucket touches the ground the bucket simply returns to the level position on the ground with no resistance.
I would appreciate input and your thoughts on what might be the problem and how to fix it.
Thank you.
   / Problem Back Blading With The 200CX loader On My JD 2520 #2
@kennyd would this be a symptom of the JD droopy bucket?
   / Problem Back Blading With The 200CX loader On My JD 2520 #4
Try reconnecting the quick couplers, see if one is not fully seated.
beenthere said:
"Try reconnecting the quick couplers, see if one is not fully seated"
That's exactly what I found to be the problem with one of the bucket quick couplers.
Problem solved!
Thank you
   / Problem Back Blading With The 200CX loader On My JD 2520 #6
I agree, just disconnect and reconnect all the quick couplers. Might not fix the problem but an easy thing to check, otherwise I’d say the seals are going bad.
   / Problem Back Blading With The 200CX loader On My JD 2520 #7
It's always good when the solution is something easy, and free. 🤣
2004 Takeuchi TB125 Mini Excavator (A49346)
2004 Takeuchi...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A51039)
2014 Ford F550 4x4...
Towable Orchard Sprayer (A49346)
Towable Orchard...
2010 Honda Civic Sedan (A50860)
2010 Honda Civic...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A48081)
2015 Chevrolet...
2007 Freightliner M2 106 Ambulance (A48081)
2007 Freightliner...
