Front-End Loader Probably a foolish question but I have to ask... Implements across brands
   / Probably a foolish question but I have to ask... Implements across brands #1
lootiejay
Clinton, North Carolina
Kubota L2501 HST
So I am looking at getting a Kubota. I went to a dealer and prices an l2501 with a FEL and a 5ft finish mower. After discounts the price is about 21,900 not including taxes.
Anyway, I was glad to have the numbers to crunch so that I knew what I was dealing with being that I will mostly likely be financing this tractor. Then a friend of mine from down the road tells me he has a FEL as well as a mower that he would sell me. 2000 for the pair.
The question I have is, will any brand of implement work or does it have to be specific to the brand of tractor and the few brands they partner with.
As I stated I am new to this and I am sure this question is relatively silly, but I am not sure.
   / Probably a foolish question but I have to ask... Implements across brands #2
A rear mower (either towed like a trailer, or mounted to the 3point hitch) will interchange between most any brand of tractor. A loader or mid mount mower (which goes under the tractor) will generally be model specific.
Aaron Z
   / Probably a foolish question but I have to ask... Implements across brands #3
Pretty much what aczlan said.
Thank you both for your replies. This definitely helps in overall pricing. I would love to be able to drop the full price and pay for it all at once, but my pockets are not that deep at the moment.
   / Probably a foolish question but I have to ask... Implements across brands #5
10-08-2016, 12:13 PM
FOXTAIL
A warning for those considering a Gear Drive Kubota L2501
I want to tell my experience with a kubota L2501 in case it's useful to anyone considering this tractor, or a L3301. They are wonderful tractors but the buyer should be aware of the following if you're not planning to get a hydrostatic....
First some background: I cut 10 acres of rough land 1-2 times per year. I did this successfully with a John Deere 1023E tractor and 4 foot Frontier RC2048 cutter. The 1023E's ground clearance around the transmission was fairly low, however, and the ride was a bit rough. So I wanted to upgrade this summer. I wanted a Deere 3032E with 5 foot cutter but it ended up being more than I wanted to pay, especially since I am unlikely to ever put that many hours on the tractor. The new Deere 3025E seemed better for my budget, but is not out as of this writing, and in any case my John Deere dealer said it has only 17.4 PTO horsepower and thought that is too little for a 5 foot cutter.
So I talked to Kubota dealers, and they were quite supportive of putting a 5 foot cutter behind a L2501, which has better PTO horsepower than the Deere (and up to 70.2 lb-ft of torque, incidentally, compared to 51.3 for the 3025E and 64.2 for the 3032E; although torque is not probably as important as PTO HP).
I ended up with a Gear Drive Kubota L2501 with 5 foot Land Pride RCR1260 cutter. The gear drive saved maybe $1000 and offered more PTO horsepower (20.5 PTO HP vs 19.0 for the L2501HST). HOWEVER, the gear drive was a big MISTAKE for my situation:
Problem 1: Nonlive PTO. When mowing if you ever need to change a gear or reverse, you must fully depress the clutch pedal, which also shuts off the transmission-driven PTO (and rear cutter). If you are in heavy material and want to slow down or back up, your only choice is to raise the mower and keep going (but not getting the grass cut) or to put the clutch in, bringing the tractor and PTO to a complete stop. (Note that the gear drive L3301 also has nonlive transmission-driven PTO. The L3901 gear drive might have the advantage of a two stage clutch pedal, which can let the PTO keep going as you change gears. However, buyers should check this carefully).
Problem 2: There are only 8 forward gears on the L2501 and they are spaced somewhat widely for mowing. It's hard to find the specs, which are only in the Kubota owner's manual and not online. Here are the details:
Low2 is 1.1 mph (much too slow for mowing except for very heavy conditions)
Low3 is 1.6 mph (very slow for mowing -- much slower than I generally did in my 1023e with a much smaller engine -- but this is the most realistic option for most conditions)
Low4 is 2.8 mph (substantially faster than L3, and generally too fast for mowing for all but the lightest material -- but still may not get a good cut because you're going so fast)
Also: on the L2501 (unlike L3301 as I understand it) there is no shuttle shift, which means that if you want to go from forward to reverse, you have to fully depress the clutch, come to a complete stop, which shuts down the PTO as well, and slowly shift and let your clutch out again. To save the clutch, the PTO and the implement, you really should do all this at fairly low RPM. However, since this action is also how you get the tractor to start moving again, you need some power -- maybe 2000 RPM to get the whole thing to go. Your left leg will really get some strength training!
Anyway, a gear drive L2501, with its transmission-driven PTO and somewhat widely spaced gears, is a little bit like a 1950s type tractor, and is not for everyone! I am sure there is someone out there who loves it, and will promptly tell me I'm just inexperienced. If someone has had a good experience with this tractor, please share.
After nearly 5 hours of frustration, my dealer let me trade up to a L2501HST, which essentially solves the problem. I would not hesitate to recommend the L2501HST to anyone wanting to run 5 foot implements.
   / Probably a foolish question but I have to ask... Implements across brands #6
As you are pricing an L2501 I recommend you also consider Kubota's 'Grand L' L3650, the lightest model Grand L.
The price of an L2501 escalates from base pretty quickly as you add options.
All the options come standard on a Grand L, AND MORE.
L3560 is 800 pounds heavier than L2501, bare tractor, has a much quieter engine, a more powerful loader and the incomparable Kubota HST/PLUS transmission.
About $27,000 with extra capacity LA805 FEL and L2296 Heavy-Duty bucket.
VIDEOS: Kubota Standard L Series VS. Grand L Series - YouTube
Kubota HST Plus Transmission Features - YouTube
   / Probably a foolish question but I have to ask... Implements across brands #7
FOXTAIL
Your assessment is spot on.
I was set to buy a 2501 but once I learned about the PTO situation, I opted for the 3901.
Thanks for sharing, this info will definitely help perspective buyers.
UNUSED JCT QUICK ATTACH 72" HYD 4N1 COMBO BUCKET (A51244)
UNUSED JCT QUICK...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52128)
2022 Down2Earth...
2016 Ford Transit Cargo Van (A50323)
2016 Ford Transit...
Topcat Skidloader Articulating Mower (A50774)
Topcat Skidloader...
Brent 420 Auger Wagon (A50514)
Brent 420 Auger...
