Pro-Ears hearing protection deal for TBN members
   / Pro-Ears hearing protection deal for TBN members #1
MChalkley
Elite Member
Eastern Virginia
EarthForce EF-5 mini-TLB (2001)
(All of the information in this posting is from my recent posts in the "Hello EarthForce, Goodbye Kubota" thread in the "Other Brands" forum, so if you've read it there, you don't need to read this.) Since this hearing protection issue is really safety related more than it is EarthForce related, I thought I'd relocate this discussion here. I've pasted information I posted elsewhere over the past few days below, including a special price for TBN members on the headset I decided to get.
(From 3/28/02): After looking at all the different brands of active electronic noise suppression headsets, I've finally ordered a set. I anguished between the Peltor and the Ridgeline Pro-Mag Dimension 2 (picture on <A target="_blank" HREF=http://www.pro-ears.com/seriesmodel.html#top>this page</A>, second model from top) from Shooters Safety Products in PA. I selected the Pro-Ears model sight-unseen (or hearing-unheard, in this case) because: 1) They use Sound Compression technology instead of sound "clipping". They will amplify anything below 70db (from 0 to 8x in 4 levels), and reduce the level of anything above 72db. The net effect is that you can hear everything all the time, whereas clipping cuts everything off when a loud noise is present. 2) Independently adjustable volume, instead of a single volume adjustment 3) 5 year warranty, instead of 6 months 4) Howard Leight, a highly respected presence in the ear protection field, has licensed the Pro-Ears technology for use in their own headset. 5) 200 hour battery life instead of 50. 6) NRR of 26, instead of 24. So much for the theory. I should have them sometime next week, at which point I'll know how well they work in practice. An interesting sidelight is that the Dimension 2 has provision for radio input, so you can control its volume using the radio, and the volume of everything else with the volume control knobs on the headset. Sure would be cool for listening to a scanner at a NASCAR race...
(From 4/9/02): I got the Pro-Ears noise suppression headset and had a chance to try them out for several hours yesterday. It was a pretty good test, because I was doing some very heavy work with the EF-500 and Brush Brute. More on that later.
The Pro-Ears worked great! You can hear as much or as little of the ambient noise as you want by adjusting the amplification of the headset via a jumper inside the ear cup. This isn't as simple as it could be, and you need a small set of needle nose pliers to do it, but at least you can adjust it. Also, both ear cups are totally self-contained, so you have to do it twice, unless you want one hear to hear different things from the other - or have hearing loss in one ear, and need to set one ear different from the other.
Using these things is a really unique experience. At first, you get the feeling they aren't working, because you still hear everything. And I mean everything, even some stuff you couldn't hear without them, if you have the amplification feature turned on. This causes some strange sensations, but you get used to them quickly. For example, I was running over quite a bit of brush, and I could hear the bushes scrape along the bottom of the machine so well that I thought they were rubbing harder than they were. Several times, I got off the machine to check for damage because I could hear brush scraping sounds that I couldn't hear before, because they were drowned out by the engine and hydraulic system noises. You get used to that quickly, though, and I really like the idea of hearing everything so well - it could save some major damage to equipment if you have a habit of listening for strange sounds, like I do.
There are independent volume controls on the outside of each earcup - the typical knobs you're used to seeing on regular headphones - which also function as on/off switches. Again, you can adjust each ear independently. It's very important to understand that these controls are completely different from the amplification jumpers I mentioned earlier. The amplification jumpers control whether and how much very low volume sounds are boosted in volume, while the volume controls determine how loud everything sounds to you. If you turn the volume control off, that ear cup functions as a simple 26db noise-reduction muff. If you turn it on, sounds are played back to your ear at whatever volume you want. Obviously, this is in addition to whatever sound makes it through the 26db reduction of the padding.
There is no control over the noise damping function, nor do I think there should be. Anything over 72db gets damped, louder sounds more than softer ones. Obviously, anything that loud is going to make it through the padding, too, so you'd be able to hear it even if the internal system didn't transmit it at all, but it does anyway. I used them a few minutes with my Stihl 038 chain saw and they worked at least as well as the Stihl ear muffs I've got.
All of the above adds up to this: I'm very pleased with them. I don't like headsets, and I like ear plugs a lot less. But I particularly dislike losing my hearing. The headsets didn't give me the "stuffy" feeling that ear plugs do, and I was able to hear normal conversation easily, even while the tractor was loud. At first, I didn't think I was going to like them at all, but I quickly decided that they're standard equipment for me when using the machine. For me, the safety aspects of being able to hear what's going, or hearing somebody shouting, are more important than the safety aspects of losing my hearing, so I've been very reluctant to wear hearing protection while using equipment. Not any more. These are the perfect solution to the problem, in my opinion. Oh yeah, I forgot to mention: I tried the Peltor noise reduction headsets at a sporting goods store over the weekend. It's not quite the same as the thorough thrashing I gave the Pro-Ears yesterday, but I didn't like them nearly as well. The main thing I disliked was that they cut out completely when you're exposed to a loud noise, so I think you'd be missing all the lower volume sounds, including safety related ones, most of the time, especially when operating at higher engine speeds.
(From 4/11/02):I've only been researching the noise reduction headsets for a couple weeks, but it's been a busy couple weeks. I've listened to three different kinds of active ("electronic") headsets, as well as compared them to passive types (plain old "muffs" and ear plugs), and I don't think anything else out there comes close to the Pro-Ears.
Here's another anecdote to add to my earlier review: Yesterday, during the land clearing project the pictures I posted yesterday were taken of, I was wearing the Pro-Ears and all of a sudden, when pushing a particularly large pile of dirt/brush/logs and climbing a pile of the same kind of stuff at the same time, I noticed a rumbling sound. So, I backed out of the pile, and looked everything over - I looked for a loose plate vibrating, stuff like that - but didn't find anything, so I went back to work. As soon as I started though, I heard the rumbling again, so I took the Pro-Ears off and then I couldn't hear it - or at least I wasn't sure I could still hear it. I thought maybe it was something strange about the Pro-Ears themselves, but I was certain I hadn't heard the rumbling sound earlier. So, I checked everything again - nothing. Went back to work, but it was still bugging me, so I stopped again. This time, I opened the hood, and started listening very carefully, cupping my hands over the microphones in the Pro-Ears, just like you'd do with your ears. I distinctly heard the sound more clearly and it was coming from the direction of the muffler, but I didn't see anything wrong. A very careful inspection revealed that a piece of flexible stainless exhaust pipe that provided the connection between the turbocharger and the muffler had pulled out of the connector it was fitted into - there was a 1/16" gap between the end of the flex and the connector. The really strange part was that neither of the other two folks who were working with me, including the one who took the pictures I posted, ever heard the rumbling sound. Suffice it to say that I'm sold on the Pro-Ears.
The other thing I noticed was that after wearing them for about 3 hours straight, when I jumped on the tractor to load it on my trailer, I decided not to put them on, because I'd only be running it a couple minutes. I couldn't believe how loud it was, and even more so, that I've been using it for more than 80 hours and didn't really think too much about it. I was really tempted to put the headset back on for just the minute or so remaining while I loaded it. The Pro-Ears are now standard equipment, and so is an extra set of the 4 "N" batteries that it takes, even though they're supposed to last 250 hours - I want to be sure I'm not without them on the job.
I heard back from John at Shooter's Safety Products today. Here's the deal: He'll give everybody at TBN a 20% discount (that's 5% more than I got). Here's what you do to get the special price. You can order them one of two ways:
1) Call John at 724-628-2437 and tell him you want the "TBN price" on a pair of Pro-Ears.
2) Order them online at <A target="_blank" HREF=http://www.shooterssafetyproducts.com/ProEarsInfo.htm>this link</A>. This is the info page, and there's a link to the order page at the bottom. When you place the order, put "TBN" in the comments field, and he'll deduct the discount when he processes the order. Your discount will not show up in the online screen, but he will deduct it before your card is charged.
For what it's worth, I ordered the Pro-Mag model, which is a little heavier, but gives you 26db of noise reduction instead of 24db. I also ordered the Dimension 2, which you might want if you're going to hook a radio up to them, but the Dimension 1 is cheaper because it doesn't have the radio input jacks.
P.S. I just noticed hours after posting this message originally that the links didn't copy across. They're working now.
   / Pro-Ears hearing protection deal for TBN members #2
MChalkey,
A very informative post. I started a discussion on this topic a while back (can't find it) and promised to let everyone know my results as well. I second everything you have said, the sound compression muffs are the way to go.
The Pro-ears can also be ordered from [link]cabelas.com[/link] under hunting accessories, but they will cost about $15 more than the deal you arranged . . . don't know about shipping differences.
I have used the Pro-ears and a product branded by Remington extensively, and the sound quality is excellent, and indistinguishable between the two. Both are sound compression models. However, the Remington pair is $99, and can be bought at Wal-mart. Basically two for the price of one. Downside is only a 90 day warranty. I have used two of the Remingtons now for 6 months and have had no problems at all. As a matter of fact, I prefer the Remingtons because they are lighter, and they don't squeeze my fat head so much. /w3tcompact/icons/laugh.gif If a warranty is important, I would buy the Pro-ears.
I use them primarilly for hunting, where they excel. My daughter used to use ear plugs, but now she can hear the ducks schusshing overhead, quacking, and whatnot, which really makes the hunt much more enjoyable. I generally use my Peltor helmet/shield/muff combo on the tractor.
fishman - I saw those on Remington's site when I was researching - they're the <A target="_blank" HREF=http://www.remington.com/NR/exeres/00001ce2twueuvnapbkrmbtg/RemArms+Rich+Product.asp?NRMODE=Published&NRORIGINALURL=%2faccessories%2fhearing_protection%2fear_muffs_r2000%2ehtm&NRNODEGUID=%7b7D1C8F8D-7D80-42CD-9013-815E4F9A1DC9%7d&NRQUERYTERMINATOR=1&cookie%5Ftest=1>R2000 model</A>, but I couldn't get any real info on them. Even Remington couldn't tell me what the Noise Reduction Rating on them was. They did tell me, though, that they aren't sound compression units, but use clipping technology. So, while they might be fine for shooting sports, I wouldn't feel safe using them on machinery.
I've been trying to find out more about them, because $99 is an awfully attractive price, but so far without much results. I've asked John at Shooter's Safety Products if he can dig up anything. He said he can get them, but won't sell them due to warranty and quality issues. I asked him if he knew of any independent tests that included the Remingtons, but he doesn't - at least not publicly available info. He said that the Marines just completed an extensive test of every electronic headset available, and decided on the Pro-Ears.
It's interesting, though, that you say you can't hear any difference between them. There should be a major difference, but if you've been using them only for impact noise, like gunshots, maybe you wouldn't have, unless you were on a range, where the loud noise was almost constant. Then, you should be able to tell that, during the periods of loud noise, you can't hear softer ones. I do know for a fact that, while they will amplify soft sounds, they won't do it in the presence of loud ones, because Remington told me that much, but only after quite a bit of prying.
I've also been trying to find out where they're made - I guess I can find that out if I look at them at WalMart. (The Pro-Ears are made in the U.S.) I'll keep digging.
   / Pro-Ears hearing protection deal for TBN members #4
Mark, thanks for moving this to its own thread. This information is very important and should have a thread that others can refer to for a long period of time. As I will not need a set for another year I hope the 20% offer will continue. Did he say there was a time limit?
PJ
PJ - No, he didn't specify that there's any time limit at all, so it shouldn't matter.
   / Pro-Ears hearing protection deal for TBN members #6
MarkC,
If you did not have the EF-5, still had the Kubota, would you buy the Pro-Ears? I've been happy with my little TC40D but this summer am facing many weekends of work to do the landscaping around the house. Not just the little stuff but removing the piles created during the excavation phase 2 years ago. These little piles are somewhere in the neighborhood of 450+ cubic yds. In addition need to do some digging around the back of the back of the house to contour the dirt away from the walk-out basement before installing retaining walls. This is probably another 40 cubic yds. All that to say that I have quite a few hours of seat time this summer.
Would you spend the money on the Pro-Ears? Up until now I just assumed that the EF-5 made more noise, hence the need for the Pro-Ears. Hence the question, would you buy them if you "just" had the Kubota?
My wife comments about how I get paranoid about different sounds from vehicles and tractors. "Did you hear that?" "Oh no, sounds like a univeral joint is going" Etc. When she heard about your experience with the Pro-Ears and hearing that rumbling noise from the muffler she just rolled her eyes /w3tcompact/icons/eyes.gif and said, "Sure, thats all you need - better ears to hear noises".
   / Pro-Ears hearing protection deal for TBN members #7
I bought a pair of the Pro-Mag Dimension 2. I have tinnitis so I can't afford to lose any more hearing.
DaveV - <font color=blue>If you did not have the EF-5, still had the Kubota, would you buy the Pro-Ears?</font color=blue> Well, that's a double-edged question... The straight honest answer to that question is "No." But, if I still had the Kubota and somebody else reported the same experience I did, I think I would. At least I hope I would.
In other words, the Kubota made enough less noise under average conditions that I never considered needing them. But now, with the benefit of having tried them, and remembering the noise level of the Kubota, I wish I'd had them then, too. The thing about noise is, you usually don't notice it until it's harmed you. At least, that seems to be my experience. I frankly was concerned that the things would be so uncomfortable that I wouldn't wear them. Instead, I've found that the peace and quiet, combined strangely with the ability to hear things I couldn't before, is so enjoyable that I can't bear not wearing them. I wouldn't have given you dime-to-a-dollar odds on that happening, I can tell you. I was expecting to have to make myself wear them.
Regarding your comment about listening for strange noises, I think you'd find the Pro-Ears a very interesting "fix" for your "habit". The reason I heard the rumbling is that the other noises were damped enough to let it through. So, instead of wondering whether you heard something or not, you know whether you heard it. It was a pretty remarkable experience. I was brought up riding in trucks - my dad had a trucking company and picked up milk from farms, first in 10-gal cans, later in bulk tanks - and I quickly developed the habit of listening to every little sound. So, I really appreciate the addition of the Pro-Ears to my mechanical problem defense arsenal, and I think you would to.
MikePA - I'm looking forward to your review of them, once you've tried them.
How bad is your tinnitus? What are the symptoms?
   / Pro-Ears hearing protection deal for TBN members #10
<font color=blue>I'm looking forward to your review of them, once you've tried them.</font color=blue>
I ordered a pair right after you posted the message about the 20% discount. I gulped at the price, but you only get one pair of ears! /w3tcompact/icons/wink.gif
<font color=blue>How bad is your tinnitus? What are the symptoms? </font color=blue>
It's not too bad. My symptom is a constant background ringing. For me it's just a nuisance, so I don't want it to get worse.
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
