Prince Restrictor Valve Size for Farmall H Loader
   / Prince Restrictor Valve Size for Farmall H Loader #1
woolyewe
Stanchfield
Farmall H
I'm trying to figure out what size orifice I should order on a prince restrictor valve for my farmall H loader. Currently there is no restrictors on the hydraulics and the bucket drops like a stone. Any help would be appreciated.
Amazon has quite a few valves listed here: Amazon.com: prince restrictor: Industrial & Scientific
   / Prince Restrictor Valve Size for Farmall H Loader #2
I don't think that you are going to want anything any smaller than 1/4". Restrictors heat up the fluid and when you have them in a loader line, it gets used a lot and the fluid really gets heated up more than it should with constant use.
Good luck
   / Prince Restrictor Valve Size for Farmall H Loader #4
A needle restricts both ways. Get a flow control and it allows full flow [up direction] and adjustable restriction [down direction]. Obviously it will come down faster loaded but you should be able to get a happy medium with the adjustable flow control. CJ
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
2012 Freightliner M2 Chipper Truck (A52377)
2012 Freightliner...
1674 (A54756)
1674 (A54756)
2012 Ford F-150 Crew Cab Pickup Truck (A53422)
2012 Ford F-150...
2007 FORD F250 XL SUPER DUTY TRUCK (A54756)
2007 FORD F250 XL...
