Prince PTO pump on BX2230
/ Prince PTO pump on BX2230 #1
formerfarmer
willmar, mn
kubota/bx2230
I bought a project wood splitter for my BX2230 tonight. I didn't want to run off of the tractor hydraulics so I waited until I found one with a PTO pump. it has a Prince pump that mounts direct on the shaft. As near as I can tell it weighs around 40 lbs. Assuming it fits (likely have to remove the guard), is there any risk to hanging this much weight on the PTO shaft?
/ Prince PTO pump on BX2230 #2
All PTO pumps are made to hang off of the shaft from what I have seen.
Also PTO's have hefty bearings to accommodate the wobble created by unbalanced shafts.
I do believe however that a tether of some kind is required to keep the pump body from wanting to spin in the direction of rotation.
I would say that you are quite safe in just letting it hang out there.
/ Prince PTO pump on BX2230 #3
Yeah, it'll be OK, like Piloon said, they will want to turn with the PTO, so to save wear and tear on hoses, bolt a long enough length of chain to it so you can secure it to one of your 3PT arms
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2006 Peterbilt 387 Semi (A64047)
2006 Peterbilt 387...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
UNUSED SDLANCH BI-PARTING WROUGHT IRON GATE (A62131)
UNUSED SDLANCH...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
