Priming the cylinder
   / Priming the cylinder #1
Tazz
Bronze Member
Texas, Montgomery Co
TC29D
I have a neighbor with a red tractor but I figure blue tractor owners can answer this just in case it were happen to me.
The other day a rubber hydraulic hose blew off the fitting on the FEL bucket (weak crimp). There was very little fluid loss but I believe that air got into the system when the new hose was installed because the bucket dropped slightly when the old hose was taken off.
My question is, do the lines or cylinders need to be primed or bled when the hoses are replaced?
Tazz
   / Priming the cylinder #2
When the hydraulics are worked they will purge the air out back to the tank.
   / Priming the cylinder #3
Just run them up and down a few times and they will purge themselves. May want to check your hydraulic fluid level after but you should be ok.
murph
Thanks all,
The fluid level was down barely 1/4 cup, still within limits on the stick. I figured that the air would have made a big bubble in the cylinder.
2004 JOHNSTON STREET SWEEPER (A52577)
2004 JOHNSTON...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2001 Volvo VNL Truck, VIN # 4V4N19JF51N250353 (A51572)
2001 Volvo VNL...
EZGO (A50324)
EZGO (A50324)
