Priming hydraulic pump
   / Priming hydraulic pump #1
Ford 3000
Hi all,
Any idea how to prime the hydraulic pump on a Ford 3000/3600?
This is the piston type pump as fitted to 3000's and early 3600's, not the gear type.
Just got pump rebuilt and I wanna get it right!
Glen
   / Priming hydraulic pump #2
The Power-Tracs have a variable speed hyd pump and has a bleed procedures when changing out filters or installation. It envolves filling the pump with fluid, and remove fuel to a diesel engine or pull a spark plug wire on gas engine so the engine does not run.
We use a tube connected to the bleed prifice in a container and motor the engine over until the air is purged.
Then tighten bleed screw and turn fuel on and start engine and let idle for a while,
You could then install gages and check some pressures in the pump like charge pressure and operating pressure.
Your system should be similar, look in the manual for your tractor for bleeding procedures.
Start-Up
On initial start-up, the case should be filled with oil,
pressure should be reduced and the circuit should be
open or the air bled from the pump outlet to permit
priming. Use of the airbleed is recommended on initial
start-up. See Installation and Mounting Section to
connect airbleed
A built in airbleed is standard on all PAVC 33, 38, 65
and 100 Pumps. To connect, remove airbleed drain
plug and connect a line unrestricted to reservoir
extending below minimum oil level. Back pressure
in this line must not exceed .28 bar (4 PSI).
Main point here is to remove all the air from the pump, and make sure the suction line is secure and tight.
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2023 G Bar K Skirted Hauler Bed (A55218)
2023 G Bar K...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
