Price Check PRICING A 650 JD W\FEL
   / PRICING A 650 JD W\FEL #1
nathanelmo
PRICING A 650 JD W\\FEL
Looking for some good advise on pricing a JD 650 w\#67 fel, 700 hrs., power steering, very clean undamaged cond., hours look correct, ag tires new in fr. dry rotted but good in rear. Probably only needs paint, a seat, and some hyd. hoses to be mint. Thanx in advance for any info.
   / PRICING A 650 JD W\FEL #2
Re: PRICING A 650 JD W\\FEL
Well, it would be nice to know a bit more about you and your location from your profile. But, here's my input anyway. I recently sold a JD 650 with a front mounted dozer blade and 2500 hrs on the clock. I got $5,000.
Now, heres a tip, but use it wisely. Greenias John Deere in Almont, Michigan has a JD650 with loader on their used lot. Maybe you could ask them how much they want for theirs. Maybe, this is the one you are talking about. (this is where having your profile filled out would help)
RE: my previous pricing a 650 JD post.- sorry about not having more info in my post. I thought my bio was filled out. I just did it now. I'll try to use the tractor for some heavy loader work ie: moving rocks 400-500 lbs., backfilling foundations & trenches, leveling grades, etc. How much counter weight can I put in back w\o causing damage to the drive train?
jim s.
   / PRICING A 650 JD W\FEL #5
Jim, the 67 loader mounted to a JD650 is capable of lifting 400 pounds. The amount of ballast needed should be around 400 lbs in the rear plus an additional 200 lbs or so to counterbalance the loader mechanism.
Note: The same loader mounted to a JD 750 tractor is spec'd to lift 700 pounds. The 750 has three more HP and is a 3 cylinder as opposed to the 650 two cylinder. I really enjoyed the 650 I owned, but if I was looking for one right now, I would look for a 750.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2020 KUBOTA RTV...
2022 LOAD TRAIL GOOSENECK TRAILER (A52472)
2022 LOAD TRAIL...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
