Price Check Price on TC45DA
   / Price on TC45DA #1
jp0933
I'm just starting out now looking for somthing bigger to replace my Kubota compact tractor... A few questions on the Boomer tractors...are the TC35DA, TC40DA and TC45DA all the same except for the engine? All physically the same size? I'm looking for a ballpark price for this following which I would initially get:
TC45DA w/ Supersteer and Turf Tires
84" 914A mid-mount mower
72CSH 72" Snowblower w/ Hydraulic chute rotation
Any additional hardware required to install implements
Maybe a year or so down the road:
Set of 4 Ag tires & Rims
17LA Loader
Would I make out better getting everything at once?
One more question...what's the best way for more traction for snowblowing? The turf tires with chains? Does NH make chain kits beause with my Kubota I had to custom make some... How well would the turftires with weights work without chains?
Thanks /forums/images/graemlins/smirk.gif
   / Price on TC45DA #2
Just purchased a TC45DA with 16LA loader. I couldn't be more impressed by the combination of refinement (loader design, hood, lights, and layout/look of the gauges and controls, etc.) and unmistakable brute force that it possesses. If you plan to turn the thing loose, make sure you invest in a little heavier duty implements.
If you would like meaningful input, you'll need to fill out your profile. The characteristics and location of your property and anticipated tractor uses are a big part of the equation.
   / Price on TC45DA
Thanks for the reply. I own about 100 acres of land in central NY. We plan on building a house there in the spring. The tractor would be used mostly for mowing the lawn and landscarping/yard chores. I know it seems like a huge tractor for that task but I want to own one tractor instead of 2 for all of my jobs. I'm thinking that the TC40DA or even the TC35DA would suit my needs but I want a tractor of the larger size. I would also use it for mowing the fields to keep the brush from growing (about 40 acres) with a Bushhog. In the winter it would be used for snowblowing. Other chores would be pulling a big wagon to haul in firewood. Right now I have a old Ferguson that is an absolute tank that we used to have on the farm (grandfather's). Use that to pull the logs out of the woods...Think the Boomer would be up to the job? Other things in the future...maybe a tiller for the garden. But for a start...lawn mowing, snowblowing, field mowing, towing, landscaping.
A few ?'s about the lawn mower... I see that the 84" is rear discharge. Any comments/opinions on this? Is the windrow a lot wider because of this? Finally...I was thinking. How do industrial tires treat the lawn. If they are fairly gentle on it...I was thinking that just a set of them would handle all jobs good instead of switching tires...
Thanks for the info guys!
   / Price on TC45DA #4
Wow, 40 acres of brush hogging, and 100 acres all together. I'd look at the TN series and get a ZTR for the yard mowing. You'd still have "one" tractor but it would handle the larger chores much better. My TC40D was too small for my (original) 40 acres and its really small for the 120 acres that I have now. My plans now are to get a ZTR, keep the TC40D, and get either a TN or TL. Then I'm ready for anything.
Seriously, though, if I had it to do over, I'd start with a TN series on that size parcel.
Just my two cents.
   / Price on TC45DA #5
JP, I think the TC40DA will be fine for the jobs you describe. I'm sure you won't mow that 40 acres all at once, so taking it in sections, the TC40DA should be fine. Also, you already have a Ferguson, so you are used to a smaller tractor. Many of the things you mentioned like finish mowing will be best suited to a smaller tractor.
The TC35 is a step down in weight and lift power by a few hundred pounds. The hydrostatic transmission's performance is the same for all the Class III Boomers. You'll find these tractors with a loader and boxblade or rotary cutter will weigh about 5000#. If you load the rear tires, you'll be up around 6000#. The tractor by itself weighs about 3400# on average. These are all rough numbers and slightly to the high side for planning purposes.
So, for the maximum lift on the 3PH and loader plus a 4-cyl engine, go with the 40 or 45. For lesser lift requirements and a 3-cyl engine, go with the 35. I think you'll be happier with the 40 or 45 based on the mix of chores you mentioned.
I'd also go with industrial tires. If you keep the air pressure fairly low, they will squat and have a lot of surface in contact with your turf. I personally don't consider the Class IIIs a good turf maintenance tractor, but many would disagree. Their advice is just as good as mine.
Good luck with your purchase. /forums/images/graemlins/cool.gif
   / Price on TC45DA #6
</font><font color="blue" class="small">( TC45DA.....about 100 acres.... I know it seems like a huge tractor for that task but I want to own one tractor instead of 2 for all of my jobs )</font>
A tc45 on 100 acers..?? doesn't seem 'huge' at all.. actually seems 'small', especially considering mowing. I'm guessing that tractor is going to pull a 7' or possibly an 8' mower..... That's gonna be alot of seat time even for 40ac of mowing. It takes me 2.5-3 hours to do 10 ac with my 7610s and 10' mower... and I've have bought a 12' or 15' if i could have found a used one near the price of the new 10' I bought.
I know you don't want 2 tractors.. but You may want a bigger one just based on mowing, unless you only plan to hit it once or twice a year. Alternately.. you can get the size you want, and have an old cheap early model ag tractor( ford 8000 or case 1xxx series ) parked out back with a beater 12' or 15' mower on it. for probably 5 grand.
I wouldn't go smaller than the 45 with that much land.. too many opertunities for other 'projects' to pop up.
Soundguy
   / Price on TC45DA #7
JP, your dilemna is somewhat typical -- a large parcel but most of the near term work will be confined to the homesite area. You are also probably thinking about getting between trees to haul things, clear things out, etc.
I have a smaller place (32 acres), but with a similar mix of characteristics (i.e., one third open areas, two thirds forested). The 45DA sure looks and feels like the right size for my place, particularly when doing most of the things you mention.
Soundguy's comment about the ideal size of brush hog for 40 acres of cutting is definitely worth considering. You might want to check up on what size the 45DA can handle and then talk to experienced folks (or demo a unit yourself) to determine if you will go crazy with impatience using that size of cutter to tame the acres you have.
Without getting a 45DA out to your property to get a sense for the "fit," it is hard to know for sure how you will feel about it (and it is your gut impression that counts). If I try to imagine my place being three times its current size, I honestly don't get the sense that would I find the 45DA way "too small." Especially with the R4s, it looks and feels like quite a subtantial machine with plenty of power for virtually any job it might be asked to do on 30 or 100 acres. At the same time, its size won't discourage you from tackling jobs that require a little maneuverability.
If you're committed to owning only one machine, I suspect that the 40DA or 45DA over time will feel like a perfectly reasonable choice (along with a few others you might make). Good luck with the move and building project.
   / Price on TC45DA #8
JP.
A 100 acres is definitely a lot of land for the 45...in my opinion. I own 97 acres in NW PA. I was looking at TC45 and TC55. However, I borrowed my Dad's 37hp Kubota a few times to mow and perform chores out in the acreage. After nearly sticking it in the lake effect snow we get around here, I decided to look larger. I purchased the TN75. I did a review in the New Holland section. I'd suggest that you at least contemplate a larger tractor. I'm glad I did. I've mowed ~30 acres and it is so much smoother (faster, more comfortable, etc.) with this machine vs. the lower HP Kubota. Also, the tires are much larger and allow for crossing deeper mud and snow, while yielding a superior ride over rough terrain. The TN has been a perfect machine for me. I can clear trails and pull out logs. Around the yard...it's ok as long as it's not wet and you're not in 4wd. I would not mow my yard with the machine though.
Just my opinion. I think you'll find the pricing is not that much more and your capability expands.
As for my yard (~4 acres)...I'm looking at those brush hog ZTR commercial mowers. Yeah...they're expensive....but should last forever and make mowing much easier/faster.
My two cents. Whatever you end up doing...good luck. Remember...it doesn't hurt to test drive them. /forums/images/graemlins/smile.gif
Shawn
   / Price on TC45DA
Thanks for the info guys...gives me a lot to think about. I should clarify that the land is about 40 field/60 wooded acres. I would only be mowing the 40 acres maybe twice a year tops just to keep the seedlings and brush from taking over. This tractor would mostly be used for lawn mowing and snow removal with a front mounted snowblower. The lawn is about 6 acres and that is the reason why I liked the 84" deck. Anyone have any opinions on finish mowing with this tractor. The lot is extremely open and not many obsticles to mow around...atleast for now. Other than that like I said before...would be used to pull logs out of the woods and haul blocked up firewood back to the house. Bucket isn't really an issue...would be used for landscaping and for maintainence of the horse stables my wife wants /forums/images/graemlins/crazy.gif
Some of my main concerns so far:
Tire chice: If the industrials will be ok on the lawn, how will they be in the winter blowing the driveway? Need weights or chains?
Cost: What am I looking at for the mower, blower, tractor and bucket?
Thanks guys /forums/images/graemlins/smile.gif
   / Price on TC45DA #10
I have the R4 tires on my TC48.I`ve did some loader work in the yard and have not seen any damage so far other than getting too big a bite with loader and slipping the tires a little.This tractor with loader and bushhog weighs about 6500lbs a lot more weight than the TC45 so, it should work fine with the R4`s.Prices have went up since purchased at 23,000 Tractor and FEL. Corriher tractors is a good place to get some price ranges
2007 GMC Acadia SUV (A50324)
2007 GMC Acadia...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2013 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
