Price Check Price on new B7510?
   / Price on new B7510? #1
RickS
Iowa Park, TX
JD 3032e
Normangee Tractor in Normangee, TX has quoted me $11,200 for a B7510 4WD gear shift tractor with FEL. Is this in line with the market? I want a PHD (post hole digger) to go with it and the quote for that was $695. That seems high to me, and the explanation was that it is shorter than the normal PHD to fit the small chassis, therefore it is a special price. A 4' box blade is $250 more. Thanks for any thoughts.
   / Price on new B7510? #2
That price seems doesn't seem outrageous. As any TBN'er will tell you, go with the dealer first, price second. You'll be happier in the long run.
   / Price on new B7510? #3
It sounds a bit high but I ended up with a 7610 and now can not remember the exact price of the 7510 when I priced it. I would suggest you look hard at a Hydrostatic model if you plan on doing a lot of FEL work. I ended up getting the Hydro model and it was WELL worth the money. It works GREAT and makes loader work effortless and extremly quick. If you can swing the cash the 7610 (about $850 more in my case) gives you more HP, and the option of a larger loader (I think it was another 150 or 200lbs roughly) I am VERY glad I went with the 7610 and larger loader because I have been using a LOT more than I ever thought I would and for a TON more things than I would have guessed. People said I would and they were 100% correct. I am glad I listened to the people on this site and bought a little bigger than I felt I needed! It was a very good move. I ended up at about 14600 for a 7610 HSD, folding ROPS, with the larger FEL and the 60" HD wheeled Mid Mount Mower (think that mower was about 2K alone) if that helps with the pricing any. Good luck
   / Price on new B7510? #4
I bought a B7510 HST with an LA302 Loader and a 54" Land Pride BB for $14K in August here in Arizona which tends to be higher than most places. I think the BB was about $600 so without taxes and the BB the price was about $12,600. This should give you some kind of an idea if you are getting a good deal. BTW, as Code54 mentioned, I would go with the HST if you are going to do any amount of FEL work. It is much easier and you will find that you get the work done much faster.
   / Price on new B7510? #5
Bought a new B7510HST with LA302 FEL for $12,600 last May in No. California (10% down, 0% APR for 36 months). Added a 48" KK box blade for $375 from Tractor Supply Co.
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
1996 Fiat Allis FG 65C Motorgrader (A51573)
1996 Fiat Allis FG...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
JOHN DEERE LOT NUMBER 72 (A53084)
JOHN DEERE LOT...
BOBCAT T595 LOT NUMBER 153 (A53084)
BOBCAT T595 LOT...
