Price Check Price of M8200?
   / Price of M8200? #1
deerepower
south carolina
JD 820
Has anyone priced a M8200 recently? 2wd or 4wd cab or without cab, as I have not completely decided on the above options yet.
   / Price of M8200? #3
I recently got a quote on a M8200 HDC3
H - Hydraulic shuttle (approx $1,000 I think)
D - 4WD
C - Cab
3 - Series 3 Cab
$32,250, Central Texas
I paid the extra $1500 and got the M9000HDC3. Its an Awesome tractor.
   / Price of M8200? #4
My M9000DTL (low profile) is a year old now but it was about 24,500. The only extra was an extra hydraulic remote. The loader for this tractor runs $5700.
This has been a great tractor.
Eric
   / Price of M8200?
</font><font color="blue" class="small">( I recently got a quote on a M8200 HDC3
D - 4WD
C - Cab
3 - Series 3 Cab
I paid the extra $1500 and got the M9000HDC3. Its an Awesome tractor. )</font>
WhiteRock the M8200 is a better deal than the M6800 quoted at $30,500 equipped exactly plus I believe the M8200 has a bigger hydraulic pump.
   / Price of M8200? #6
The M5700, M6800, and M8200 all have the same hydraulic pump specs. Each being 17.1 GPM. The M5700 and M6800 deliver 2770 PSI, while the M8200 delivers its flow at 2880 PSI.
It does have higher pressure, so more output, but not by much. The flow is total flow including power steering. So you only have 11 GPM for hydraulic implements at the service outputs.
One of the reasons I went to the M9000 was because it has an extra pump dedicated to the power steering. So the full 17.1 GPM at 2880 PSI is available at the service outputs. This isn't really high flow, but it puts you in a nice range for a lot of hydraulic implements. Especially for a tractor.
I hope this helps
   / Price of M8200? #7
I just realized your are the topic originator. Sounds like you are still trying to decide. So I will throw in some more observations so you can see if they match yours.
For the $2,000 difference here is the advantage the M8200 has over the M6800 that I see:
- 15 gross, 11 PTO more HP from turbo
- CAT II hitch only, but far as I know you can use still use the adapters
- 1,000 lbs lift capacity
- Increased fuel capacity 5 gal ROPS, 4 gal cab
- Increased cooling system
- approx 1 ft in length
- about 4" wider
- 1.5" ground clearance
- 8" in wheelbase
- 500 - 1000 lbs in weight depending on model
- Bigger tires, I think this may be the weight and size difference
Depending on what you will use it for will determine the value of the differences.
So far with my M9000 I have never run out of HP. I always run out of weight first. So I probably would not notice with my current task if I had 15 less HP. I am sure there are implements that would tap the HP. I am sure hydraulics would be one. These tractors have a lot of power.
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2012 KENWORTH T370 PROPANE TRANSPORTATION TRUCK (A52472)
2012 KENWORTH T370...
