price for kubota b7610?
   / price for kubota b7610? #3
Hi, bigballer. Welcome to TBN.
If that price includes the LA352 front end loader, it's a good price. If not, it's too much. What type of rear mower; rear finish mower or bush hog?
Last month I was quoted $15750 for a new B7610 with RCK60 mid-mount mower, ballast box, and an LA352 FEL. Figuring the FEL is around $3700, that leaves $12000 for a new tractor and mid-mount mower....and the mid-mount mowers are usually higher priced than rear mowers.
Bob
   / price for kubota b7610? #4
Bob
thank you mr. young. this website has been invaluable so far, i'm glad to be onboard. regarding the tractor: there is an fel on it but not sure of the model (per kubota site, the 352 is "standard" but am confirming with seller). the mower is a finishing model (also confirming model/size). btw, can this be used effectively on tall pasture grass and weeds? what is the difference really between a brushhog and finisher? i suppose it's the number of blades as well as the shape of the cutting pattern but am not really sure.
cheers,
bigballer
cheers,
bigballer
   / price for kubota b7610? #7
Weeds and tall pasture grass should be no problem for a finish mower but the more important question is "what else are you going to run over out in the pasture?" Hitting old stumps, bottles, rocks etc would damage a finish mower but would only cause a nasty noise when hit by a "brush hog". If the pasture, when cut, really looks like a lawn and if you are reasonably sure there are no hidden surprises, then the finish mower could do the job. If you have doubts, see if you can rent a brush hog at least the first time you mow.
   / price for kubota b7610? #8
   / price for kubota b7610? #9
Check out this web sight. It has a price layout that shows 3 different levels of pricing.
http://kazez.com/will/kubota.html
Of course this thread will probably get moved to Kubota pricing/buying. /forums/images/graemlins/shocked.gif
Sorry, didn't see right off the fact you were talking used. Well now you can compare to new. /forums/images/graemlins/grin.gif
   / price for kubota b7610? #10
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51692)
2023 Stryker...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
