Price check please
   / Price check please #1
keegs
Veteran Member
The County, ME
Kubota M5640SUD
Still looking for a tractor to cut 50+ hay acres. Stopped by the local Kioti dealer and he quoted me $19889 for a new DS 4110 hs which included a loader and 6 ft rotary cutter. The loader was a manufacturer incentive and no charge. Seemed like pretty good price.... though I'd just come from the JD dealer..:laughing:
Your thoughts?
   / Price check please #2
well lets see..... 41 horse tractor with hydro shuttle, Independent electric/hydraulic PTO, 2761 lbs lift at the pivot pins on the loader, and a rotary cutter of some kind, all for less than 20 grand.? You could do a lot worse.
James K0UA
   / Price check please #3
That does seem like a good price. I got my DK40se HST for $19,500 with FEL last summer as a point of reference.
Did you get the belly PTO with yours at that price? That option doesn't appear to be available in the DS. As well, the FEL incentive isn't available on the DK. Not sure what trouble one could get into with the shuttle trans on the DS.
   / Price check please #5
You said to "cut 50+ hay acres" - IF you are talking about cutting and baling it with this tractor, I'm gonna suggest you check the mower and baler you are gonna use for their hp requirements. I run a Kubota M7040 (~68hp) to hay about 25 acres, and sure don't want anything any smaller. If you are just gonna bush-hog, that would do it.
Bush hog primarily but also hauling firewood through the wood, snow removal, box blade gravel drive...
   / Price check please #7
Keegs,
No belly PTO that I'm aware of. I run all my PTO attachments from the 3-point. I really like the Hydro transmission. It cost a bit more, but it makes life so much easier in every application I've used it in so far.
Good luck!
   / Price check please #8
The shuttle transmission on my 300hr DS4510 has performed faultlessly for 300hrs of brushogging. Very good value for your dollar.
I did some follow-up on this. The mid PTO apparently is available on the DK series but not on the DS. It's a $300 kit option. I was interested on the front mount snowblower which requires the mid-PTO. The loader incentive is available on the DK as well as the DS series.
There's been a fair number of complaints on this forum about what seems to me to be quality consistancy.
   / Price check please #10
I think no loader incentive for dk this quarter fyi.
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55218)
PENDING SELLER...
14ft. Deer Gate (A53424)
14ft. Deer Gate...
