Price Check Price check: JD 770
   / Price check: JD 770 #1
GlueGuy
Veteran Member
San Francisco Bay Area California (CA)
Kubota B7500
On my way into work this morning, somebody had a used 770 out for sale. It has 140 hours on it, and what looks like an Alamo 60" tiller. The poster on it wasn't clear whether the tiller was included or not, but they are asking $10,500 for the thing. Is this a reasonable price? It didn't look like anything was leaking or abused, but the faded paint looked like it was probably stored outside.
The GlueGuy
   / Price check: JD 770 #2
Was it 4 WD ? and did it have DSCV ( the long joy stick on the right hand side) ? And What kind of tires ( R1s, R4s, Turfs) ?
THANKS JIM
Jim,
It is 4WD, I didn't notice the DSCV (what's that?), and it has a tires with a lot of tread (didn't look like they'd been used much).
The GlueGuy
   / Price check: JD 770 #4
The DSCV. is the valve assembly for use with a front end loader and other attachments . Its a joy stick that is on the right hand side of the tractor when your sitting on it and its about 18" tall and has a couple of bends in it. its a $600.00+ option thats a must if you ever want to add a loader.
JIM
Stopped by and looked at it on the way into work this morning. There are a couple of "long handled" controls on the right side of the tractor. One is near the bottom-right-front of the seat, and the other is right above the brake pedals. The one above the brake pedals has a red knob, the one by the seat has a black knob. There are quick disconnects on the left side in front of the floorboard, so I presume that's where the DSCV control leads to.
The GlueGuy
Called the guy to get more information. It's been used on a small (2.5 acre) vinyard for 3 years. They added a couple more acres on steeper terain, and needed a crawler to negotiate it. The Alamo implement that I "thought" was a tiller is actually a flail mower. They are also dropping the price to $8,000 complete with the flail mower (but no FEL or anything else). It is plumbed for a FEL, and has the joystick. Also has a full set of front weights.
The GlueGuy
   / Price check: JD 770 #7
That sounds like a really good deal to me . The replacement tractor of that model is the 790. It has a few upgrades most of which is a few more horse power. It sells for 10,995 in 4wd and you would have to give another $650.00 for the DSCV and another $150.00 for the plumbing for the out let assy. for the front end loader. I think its $75.00 per front weight. Any way it starts adding up quick. GOOD LUCK!
JIM
   / Price check: JD 770 #9
JD770 4WD, Mfr. 1989-97, 20 PTO HP, 2105 lbs., Last List $12,850.
Auction Pricing -Low/Avg/High
$4800, $5900, $8500
   / Price check: JD 770 #10
John,
Would you happen to have the price for a Gehl 4610 perkins diesel skidloader?
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2015 F-550 Bucket Truck Gas Engine (A51039)
2015 F-550 Bucket...
Landoll (A50657)
Landoll (A50657)
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
