Price Check For Mechanic Work
   / Price Check For Mechanic Work #1
Travis_R
Veteran Member
Livingston Parish, LA
Yanmar YM2500
What do you guys think is a fair price for a tractor mechanic to come to my house and work on my tractor?
Here is the info:
-He's about 1 hour and 45 minutes away (roughly 103 miles).
-He will be rebuilding the power steering pump and re-packing one of the steering cylinders.
-He'll be picking up the parts.
What would be considered a fair price for his driving time and labor (not including parts)?
I've never met the guy, just seen his ad and called.
   / Price Check For Mechanic Work #2
My local Kubota dealer bills mechanic's time at $70 per hour.
   / Price Check For Mechanic Work #3
It'll be rough. I wouldn't be surprised if he charges mileage on a trip that distance on top of his hourly rate. You'd be way better off to pull the parts yourself or find someone closer. The local dealership charges like $75 an hour for in shop work. What price did he tell you when you called?
   / Price Check For Mechanic Work #4
I think you could be close to a grand with parts, four hours of driving, fuel and five hours of work.
   / Price Check For Mechanic Work #5
Be glad you do not live on the west coast close to urban areas. $125/hr both working and traveling plus a mileage rate. Construction equipment is $175/hr. Great incentive to do your own work like I do.
Ron
   / Price Check For Mechanic Work #6
Travel: $200 (200 miles @ $1.00 per mile)
Repair Time: $400 ( 4 hours at $100 per hour)
Parts: $500 (pure guess)
Total estimate: $1100
This is a pure guestimation on my part. I have no idea how much it is going to cost. Let us know the outcome. I am curious.
   / Price Check For Mechanic Work #7
The four hours and 200 miles of driving are going to kill you price-wise. You could probably buy a new pump and cylinder and install yourself for the same price.
Or, have the cylinder rebuilt at a local hydraulics shop and buy a new pump.
I also think you are in the $1K ballpark.
Just checked on-line - PS pump is 180 bucks. Cylinder rebuild is going to cost you a hundred or so for parts and labor at a local shop. This would be a fraction of the price you will pay for a turn-key job.
The problem comes when he picks up parts and finds something else that is in need of repair - power steering lines, etc. Then what? Have him go for parts? Come back again at full mileage / time charge? Leave it half done? If you are physically able, it is wise to learn to do these things yourself. If not, find a local guy.
Good luck.
   / Price Check For Mechanic Work #8
If all you can get from a repair shop is the labor/hr then you are most likely getting screwed imao. The best method to accurately compare prices between shops is to get a total quote on the whole repair. Tell them you don't care if they are $70/hr or $150/hr just give me a quote on the job... 1 figure only. Only quoting the labor rate not combined with total amount of hours needed is a terribly dishonest practice mastered by many a repair shop to advertise a "lower rate" than their competitors.
   / Price Check For Mechanic Work #9
I would charge my normal hourly rate for travel. Is there a compelling reason to use someone so far away? Someone local even if more costly per hour will be cheaper.
John Deere Imatch Quick Hitch (A50514)
John Deere Imatch...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
22ft Progressive Finish Mower (A52128)
22ft Progressive...
1995 Case IH 2144 Combine (A50514)
1995 Case IH 2144...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2010 Toyota Tundra (A50323)
2010 Toyota Tundra...
