Price Check Price check 2001 770
   / Price check 2001 770 #1
Chris osborn
John deer 770
Great shape!! Has shade cover 4wd stick shift! 325hrs
   / Price check 2001 770 #2
Are you buying or selling?
If in good to excellent shape, with a loader, I'd say it would be $8000 minimum as an asking price and about $12000 maximum.
The 770 has 24 gross (engine) HP and 20 PTO HP. Good tractor...basically the same as the 790 and 3005 with a bit less power.
   / Price check 2001 770 #3
The 770 has 24 gross (engine) HP and 24 PTO HP. Good tractor...basically the same as the 790 and 3005 with a bit less power.
Roy's numbers here are correct and accurate except for the pto power. PTO on the 770 is 20hp@pto.
As for price, once again, I agree with Roy....$10,000, give or take.
   / Price check 2001 770 #4
   / Price check 2001 770 #5
Chris,
You might want to give your local John Deere dealer a call to verify the year of that JD770. Last year they made that tractor was 1998. Give them the serial number of the tractor located on a plate by the PTO shaft and they will be able to tell you the year it was made. You may get more info (if it has been reported stolen; what options it came with; etc) if you are able to contact the JD dealer that initially sold the tractor to its first owner (if known).
You can also go to this site to see what year your serial number falls into:
TractorData.com John Deere 770 tractor information
My JD70 loader on my JD770 had the original dealer sticker on it. They were bought out by another local JD dealer. I contacted them and they gave me the year made and month sold; original owner's name; that it was not reported stolen; and options.
Bruce
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2015 FORD E350 16FT BOX TRUCK (A52576)
2015 FORD E350...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
