DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,578
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
I need to re-seed part of my small hay field, due to running short on hay, and buying a couple not so good round bales, with some noxious weeds in them, a couple years ago. When I spread the manure from around the hay feeder with these seeds in it onto the hay field, I got a growth of some not so welcome weeds, mainly Foxtail, and Larkspur. After seeing it during first cutting, I skipped that part of the field, and mowed it down with the flail mower, then continued to mow the regrowth, before getting to the seed head stage throughout the summer. I did this until early Sept., planning on doing a complete kill with Glyphosate. We had an unusual hot spell that was in the upper 80-low 90's, so it was time to spray. Got a good kill, and luckily it was when grass had just been mowed, and very little regrowth.
Looking over some preferred palatable grasses, I came across a "new" old grass. Preval Meadow Fescue. Just wondering if anyone has sowed this on hay, or pasture ground, and what were the results. I'm looking for something more leafy, rather than the Rye Grass that tends to be more stemmy on first cutting. It's OK for second, and third, being regrowth it's more leafy. The horses waste a lot of the first cutting stemmy hay, going for the finer grasses/clover/alfalfa/timothy.
I have found a seed dealer fairly close that handles it, and planning to call them here next week, after the holidays, and see if they do have it in stock, to do some frost seeding late Feb. early March, overseeding the whole field with the Preval. It is my preferred way to reseed/over seed on both hay, and pasture ground, and have always had excellent results. In the product description, it says Preval hashad excellent greminationresults with using the frost seeding method, so that is a big plus. I'll also make a second pass, seeding the kill area with the other mix of red clover, alfalfa, timothy, and probably some bluegrass.
From doing more than several hours of looking at Meadow Fescue's, Preval seems to be the best, of the best. So, thought I'd give it a shot. Just wondering if anyone else has tried it, and what were the results. I'm feeding pleasure horses, so don't need anything too hot, just some 12%-14% palatable belly stuffer.
