Pressure Washer Throttle
   / Pressure Washer Throttle #1
seapea
SF Bay
Kubtoa B2620
I have a Devilbiss Excel pressure washer, 2400 PSI with Honda 5HP engine. Purchased from Home Depot about 4 years ago. Today I noticed that when I move the throttle lever to the full throttle setting, it does not actually run the engine at full throttle. If I pull on the throttle cable it revs up the engine quite a bit more. So much more that I was a bit alarmed and thought I might be overrunning the engine or the pump, so I only did it for a couple of seconds.
I don't use this pressure washer often to know if this is the way it's always operated. My question is, is the pressure washer intentionally under throttled in order to properly work with (not damage) the pump? If so, how do you tell what the proper amount of throttle is? Throttle cables have a habit of loosening up over the years, so at some point an adjustment will be needed..
   / Pressure Washer Throttle #2
I rented a stump grinder from Home Depot a few weeks ago. It had a Tach/Hour meter on it. Seemed to work good.
Click Here
I am looking for one that will work on all small engines for testing.
My Home Depot pressure washer sounds like it is running the correct RPM's. It is only 1 1/2 years old.
   / Pressure Washer Throttle #3
Dosen't your owners manuel tell you how to adjust the throttle cable?
</font><font color="blue" class="small">( Dosen't your owners manuel tell you how to adjust the throttle cable? )</font>
The operator's manual for the unit does not mention throttle adjustment. The engine manual also provides no useful information about throttle adjustment, except to say that it provides 4.9hp at 3600 rpm.
   / Pressure Washer Throttle #5
"Today I noticed that when I move the throttle lever to the full throttle setting, it does not actually run the engine at full throttle."
I would imagine it runs at the correct speed it was designed for.
Mini trencher attachment (A53421)
Mini trencher...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
Land Pride RCF2072 (A50123)
Land Pride RCF2072...
2016 Great Dane 102"x48' Step Deck (A50123)
2016 Great Dane...
Brushfox XHD-72 (A53421)
Brushfox XHD-72...
