Pressure washer sand blasting
   / Pressure washer sand blasting #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Some of us get rust and dirt, grease and oil on our tractors, and here is a very good way to clean all that up for restoration and painting and whatever.
Here is a sand blast kit for a pressure washer to do all of that above.
The sand has to come into the nozzle from above the nozzle, so I made a backpack that contains the sand.
The tube comes over my shoulder and feeds the nozzle.
Watch the video and decide yourself if it is worth while.
General Pump High-Pressure Abrasive Blasting Kit — 3500 Max. PSI | Pressure Washer Hoses| Northern Tool + Equipment
https://www.youtube.com/watch?v=kfA-IkaMRGE
Can also clean up those rusty tools in short order.
Just dry and spray alcohol to get rid if the water, and paint or whatever.
   / Pressure washer sand blasting #2
Are you kidding me, thats awesome,:eek:
I have one of those 20 gallon thingys for sandblasting,
I wonder if it could be adapted to this setup somehow.
I like the idea of, "no sand dust" flying "everywhere.
I'll be ordering one for sure, wonder what the cost is to ship to Canada, or even if they do.
Lets see some pics of your set-up, JJ...
What grade of sand do you use or does it matter.
You got me hooked on this now....:mad::thumbsup:
   / Pressure washer sand blasting #3
I've often thought about building something like this. Seems like a natural combination but I'm sure there is some reason it's not more widely used.
   / Pressure washer sand blasting #4
That looks like a really nice set-up and works well. Only thing is using the water it will begin to rust in minutes after it dries so painting will need to come quick....
The trick to using the sand blaster is to keep the sand hose on top of the nozzle.
You need the second tube on the suction end of the sand tube to let air in.
I use dry play sand that comes in bags and then filter to get the lumps out.
https://www.google.com/url?sa=t&rct...=_quJXdBdzOIQm56Ob3voVw&bvm=bv.64507335,d.b2I
I use a bucket of back pack for the sand.
You can probably make your own nozzle, It appears to use the venturi effect to simply suck in sand and mix with the water
You can do a lot of thing with this rig. Strip rust, clean cement, strip paint, texture wood, etch glass, etc.
Definitely wear eye protection, maybe hat.
   / Pressure washer sand blasting #6
Probably the speed and maybe the mess too? Wet play sand sticks to everything. My pressure pot would blast the whole side of the tank off in the time of the video. I use play sand in my pot and wait for a day with a little bit of a breeze and go to town. I never had issues with dust, the sand flies in maybe a 20ft diameter circle and that's about it, it washes into the ground after a few good rain storms. Guess if you lived in town or didn't have a sufficient air compressor this would be the next best thing. Utilize what you have.
   / Pressure washer sand blasting #7
I have a pressure pot that works great but I wonder if on heavily rusted metal 3000lbs of pressure would do better than 140.
Bill
   / Pressure washer sand blasting #8
Thank's, JJ, I'm hooked, for under a 100, it's well worth the effort of
giving it a shot.:thumbsup:
Was never aware of something like this....and it looks like its worth a try.
   / Pressure washer sand blasting #9
Dunno, I don't see commercial sandblasters using them so that probably tells you something. I just wonder why the pressure pots work better than a standard siphon feed. My guess is the pressure pot has a long time to speed the sand up and give it some momentum. A siphon blaster just sucks it up quickly and sprays it out, not giving it much time or momentum to do as much work. This is basically a siphon feed blaster used in conjunction with a pressure washer. I still like the fact I can blast my parts, take them inside and spray them right away.
   / Pressure washer sand blasting #10
The key to siphon feed is dry properly sized sand. I wonder if pressure washer creates more suction ??? I would love to hear any real life experience with this tool ? It may be worth a gamble for 100 bucks. Any happy or unhappy owners out there ?
Case 580SM Series 3 (A42021)
Case 580SM Series...
CAT 953 (A42021)
CAT 953 (A42021)
2011 Ford F-450 Ambulance (A42742)
2011 Ford F-450...
2007 MACK CTP (GRANITE) (A45046)
2007 MACK CTP...
2014 MACK CHU (PINNACLE) (A45046)
2014 MACK CHU...
1998 MACK CH613 (A45046)
1998 MACK CH613...
