Pressure washer help..
   / Pressure washer help.. #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
I need to pressure wash my house, but I am confused with mixing of the detergents. The house wash I bought says to mix it 1:19 with water. This much I understand, but do I change this ratio if I let it siphon the detergent out of a bucket? Or do I siphon it directly at full strength.
The last time I used this set up for washing my car wash I siphoned it out of the bottle and used almost an entire bottle for one vehicle.. Way to strong.
Thanks for any ideas
Brian
Brian
   / Pressure washer help.. #3
siphoning at full strength would be next to impossible to get the correct ratio. I would mix it in a 5 gallon bucket & siphon from there. But then again, I would never pressure wash the house /forums/images/graemlins/smirk.gif
   / Pressure washer help.. #4
   / Pressure washer help.. #5
Different power washers inject chemicals at different rates. Mine injects at 7:1, so if the mixing rate on the chemical calls for 14:1, I dilute the chemical 50:50 with water. So now my unit is mixing at the correct ratio. Some units have an adjustable injection ratio, mine doesn't.
The instruction manual did not state the mix ratio, I had to call their help number and ask.
And don't forget that they usually only inject chemicals at the low pressure setting.
   / Pressure washer help.. #6
Thanks for the feedback.. I finally got an answer from Karcher and my system dilutes it at 18:1, close enough to 19:1 for government work I think.. I dont understand why they dont put that in the owners manual..
thanks
Brian
thanks
Brian
   / Pressure washer help.. #9
Glad that it might have helped.
I was investigating a unit with an adjustable injection rate, but realized that if it used a neddle valve or similar you'd never know what the rate was because you'd have no way to calibrate it.
A known fixed rate is better because you can mix your concentrate to get the end result you need.
   / Pressure washer help.. #10
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
434669 (A48836)
434669 (A48836)
2007 FELLA SM350 3 PT DISC MOWER (A55301)
2007 FELLA SM350 3...
2001 CHEVEROLET C6500 3 CAR ROLL BACK (A54607)
2001 CHEVEROLET...
