Pressure Washer for Cleaning
   / Pressure Washer for Cleaning #1
dlockh4258
Lexington Kentucky
Kubota B2910
I'm thinking about buying a pressure washer to clean my B2910 with and I was wondering what PSI is best. I want to get a washer that will not strip the paint. What PSI is too strong for auto or anything of that nature?
   / Pressure Washer for Cleaning #2
David,
If you look at the search feature, you will find alot of pressure washer discussion. I have a Generac 2400psi model, and have found that the nozzle angle is the important variable for avoiding paint stripping. I use the 40 degree nozzle for general rinsing, and step down to a 25 for the underside of the vehicles. The 15 degree nozzle is only used for the mower deck. I don't know what the 0 degree nozzle would be for, unless you actually want to strip paint. Hope this helps,
Will
   / Pressure Washer for Cleaning #3
Its a common mistake to think of pressure as the more important decision when getting a pressure washer. It's the GPM that is really the most important with pressure washers. Its a trade off with a given HP. Put simply, I'd rather have a 1500 to 2000PSI machine at 3 gpm then a 2500 to 3000 PSI machine at 2 gpm. I have a little electric pressure washer that has plenty of pressure but very little volume. I also have a gas at 3500 PSI and 4 gpm. I can easily use the larger washer on my tractor, leaving the decals, paint etc. fine if I'm using the wider angle tip (usually white colored). When it comes to pressure washers that most folks get at places like Home Depot, your decision about pressure is very limited based on price. 5 to 6 HP, $600, will get you around 2.5 gpm and 2000 PSI. Always opt for the higher GPM when you can. Wheter its 1500 PSI, 2000 PSI or higher, you will find all do a pretty good job. If you want to really see how volume affects the time and practicality it takes to wash down something, try using a airless paint sprayer. Basically a pressure washer with high pressure, 3000 PSI and up but very low GPM, typically well under 1 GPM. It would take some time even if the proper tip could be had. Rat...
   / Pressure Washer for Cleaning #4
Most have adjustable outlet pressure. As you increase the pressure using the pressure knob the GPM decreases, reduce pressure and the GPM increases. J
   / Pressure Washer for Cleaning #5
actually , i don't use my pressure washer to clean my tractor or vehicles. but if u do, most washers have an adjustable outlet pressure, just be sure not to use very high pressure when it is not needed also the distace u are form what u are cleaning will effect greatly how much pressure u are applying, start farther back and move in as the task requires.
5 (A59228)
5 (A59228)
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
Westfield Conveyor (A56436)
Westfield Conveyor...
UNUSED FUTURE STP45 HYD BREAKER HAMMER (A58376)
UNUSED FUTURE...
20FT X 12FT LIVESTOCK METAL SHED (A58216)
20FT X 12FT...
401 (A52706)
401 (A52706)
