pressure relief or faulty drain plug?
   / pressure relief or faulty drain plug? #1
bfoote
Western, Massachusetts
AC 5050
I have an Allis Chalmers 5050, and was working it yesterday moving blocks of firewood. I loaded a lot of blocks into the bucket, and the tractor was working a bit, but I only moved three loads, and then called it quits. When I was going to park the tractor, I noticed a steady stream of antifreeze coming out of the drain plug on the lower radiator hose. Its a drain plug, and it has a nut which bolts it on the lower radiator arm. I quickly looked at my temp guage before shutting off the tractor, and it was not showing the tractor running hot? I shut off the tractor, and the antifreeze was starting to slow down coming out of the drain plug, so I thought that removing the radiator cap would take the remaining pressure away, but when I removed the cap, the stream started coming out full stream again. I replaced the cap, the fluid stopped coming after a minute or so, maybe a half gallon came out. Now I'm questioning whether this is a faulty plug, or is there a pressure relief valve built into this? Thanks in advance...
   / pressure relief or faulty drain plug? #2
If it leaked worse whe you loosened the cap, then I'd have to say it's a leak as that's when there would be *no* pressure in the system.
Now the leak could be due to a bad pressure relief valve, but I've never seen a pressure relief valve on a cooling system (other than the cap itself), and anyway, a pressure relief should *not* be on the bottom of the system (where it would bleed fluid), it should at the *top* (where it would bleed air)
Long story short - sounds like you have a bad plug...
2023 Power Skid Steer Loader (A50322)
2023 Power Skid...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52748)
Koyker Loader...
Ford 5610 (A50120)
Ford 5610 (A50120)
2019 Freightliner M2 106 Landscape Dump Truck (A50323)
2019 Freightliner...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
