Has anybody seen press-in zerks used at the factory level for drive shaft U joints ?
DRIVE TYPE GREASE FITTINGS, PRESS-IN GREASE FITTINGS, PRESS-IN ZERK FITTINGS, DRIVABLE GREASE FITTINGS
I'm asking because today, when I went to grease the U joint my buddy installed for me 3 months back, well.... there was no zerk there, just a hole. This vehicle does not go off-road, and there is no impact damage, just a clean hole through into the U joint body. I recall the zerk being on the U joint at the time of installation.
Probing the hole with a pick shows just smooth walls, no threads. My guess is that a poorly fitting press-in (or Drive type) zerk was installed at the factory, then got flung off at highway speed.
Didn't know these fittings existed, till today. With the appropriate materials and QC, I can see how a press-in fitting MIGHT work properly, for low pressure applications. I'm afraid I'm seeing just another cost cutting factor that is introducing a point of failure in a critical part.
D.
