3-Point Hitch Preserving three point lift capacity with quick hitch.
   / Preserving three point lift capacity with quick hitch. #1
jenrow33
Bronze Member
Michigan
Kubota L3400HST
Bought a quick hitch three years ago, haven’t taken it off , love it. The hitch offsets implement pins by 4”. As most of us know this creates pto shaft length problems. My problem is different. I move firewood pallets with my tractor and a three point fork set. After installing QH I notice a definite capacity decrease, no doubt due to the load being 4” further from the tractor.
I’ve searched for a new shorter set of three point arms to bring the pins back to their factory distance but haven’t found anything. Is this a real option?
On my machine the math works out to a 15% lift capacity decrease currently at the center of the pallet load compared to no QH. I don’t want to have to remove the QH as that defeats its purpose! Any other ideas....other than a bigger tractor?
   / Preserving three point lift capacity with quick hitch. #3
Also, check what PSI of your hydraulic system. Most are set on the low side and you can increase the PSI a bit (...with some risk but I have not seen/heard of any problems doing this on these forums from people whom have increased it).
   / Preserving three point lift capacity with quick hitch. #4
Frequently the lifting arms have holes for different connection points from the three point levers. You may be able to just change the connection point to increase your leverage though you will decrease the height of lift.
Investigated this and my tractor, kubota L3400, does not have multiple leverage holes in the arms.....well it didn’t until now. Added another set of 9/16” holes 3” further back and notice a difference in lift. Problem solved.
1240 (A50490)
1240 (A50490)
2015 FREIGHTLINER CASCADIA DAY CAB (A51222)
2015 FREIGHTLINER...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
