Snow Equipment Owning/Operating Prepping 3pt snowblower for winter
   / Prepping 3pt snowblower for winter #1
ScottyChip
Newfoundland, Canada
Kubota B7510
Hi All
Need to ready my 3pt snowblower for winter and I am planning to complete some paint touch-up, check the gear box oil, and grease the auger and bearings.
Wondering if I should grease the pto shaft? What does everyone else do to get their equipment ready for winter? Is there one grease that outperforms others?
Thanks. I have learned so much from all the advice, tips and information on the site. The temperature is dropping quickly and I know winter is coming.
ScottyChip
   / Prepping 3pt snowblower for winter #2
Hi All
ScottyChip
You should grease the zerks in the yokes and a light film of grease on the inner shaft (of the collapsible section). It's probably better if you separate those sections completely, but I just pull them apart (about full extension) and smear grease on the inner section. I figure the collapsing and extension during operation should result in complete coverage.
I use standard EP grease...same stuff I use in the loader and tractor zerks.
I don't remove the PTO from the implement...actually easier to extend the PTO drive shaft with it connected to an implement.
   / Prepping 3pt snowblower for winter #3
I pull my chute off once a year [ do my PM'n in the spring ] and re-coat the 'bearing' surfaces with lithium grease. I just use the white lithium, but I have seen blue lithium that is supposed to be low temp. You can clean and paint these surfaces, but as long as there is a coating of grease it will not rust. The reason I PM in the spring, is that I like to get all the metal coated back up with a layer of Rustoleum before storage.
Thanks Roy and Jerry. I would probably found out the hard way to not remove the shaft from the implement. I agree, I should have PM'd in the spring, when it was warmer and dryer, but why do today when you can put off till tomorrow. A motto, I try not to live by, but life sometimes gets in the way.
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
2013 JOHN DEERE 8235R LOT NUMBER 205 (A53084)
2013 JOHN DEERE...
2014 RAM 5500 Bucket Truck - 4X4 - Cummins Diesel - Automatic Transmission -Versalift SST40 Boom (A53472)
2014 RAM 5500...
