Dougster
Veteran Member
Yet again, I turn to my highly experienced friends on TBN for a little advice. Up until now, spreading and raking out prescreened loam has been pretty straightforward and uneventful. I'm typically dealing with relatively small areas, often with a little re-grading and/or stump removal to do first. Occasionally, a large rock or two has to be pulled out. Other than that, very little has needed to be done before the loam trucks arrive and I go to work.
But what do you do when you are dealing with a fairly large area of low-quality, hard-packed fill that has set up like concrete? This stuff is 1/3 clay, 1/3 mixed gravel and 1/3 various sized rocks & debris. I don't even know if I can bite very far into it except with the backhoe... and I'm afraid it will ruin my boxblade if I go that route first. It's that nasty! I'd be tempted to back-drag the worst areas with a heavy-duty toothed bucket first (before attacking with the boxblade), but I don't have one yet and now it looks like I might not have one for some time to come.
Should I just ignore this concrete-like fill, remove the worst offending surface stones... and simply spread the loam as usual? Or would you prepare the existing surface first... either by bringing in sand or something else to layer between the hard-packed fill and loam... or maybe by some sort of mechanical preparation of the hard-packed fill? Or both? I do not mind going with rental equipment if that's ultimately going to provide the best solution and save my own equipment from yet another nasty, unnecessary beating.
Dougster
Dougster
