preparing metal for electroplating
   / preparing metal for electroplating #1
wwwfarmer
Hello everyone!
I've made a tractor implement to assist me with picking up onions and root crops, similar to this one:
I was thinking of painting the sidewalls and the bottom lifting blade, but regardless of paint used, the abrasive nature of soil will remove the paint, leaving the implement looking like this: https://www.huckinsforge.com/wp-content/gallery/bed-lifter/Ten-Lakes-Lifter-1.jpg
In my opinion, the shiny metal surface is very visually appealing. I'd like to grind it evenly and apply zinc coating via electroplating (not hot dipping). One of my tools I have has been zinc coated and it looks magnificent. Take a look: example-1, example-2. After the zinc is abraded away, probably as quickly as paint, shiny metal surface is underneath.
The other thing that I noticed is that because the zinc applied is very thin all the surface scratches are very visible. It is mandatory that I perform an even grinding when preparing the metal surface (I am using hardox 450 with primer on it). The maker of this product - http://twobadcatsllc.com/index_files/bedlifterfs.jpg had a similar taste, but notice how bad it looks compared with the fork I attached as example, due to uneven grinding.
This is my first time preparing hardox for zinc electroplating, in fact I only have a month of metal working under by belt. What are the necessary preparation steps and what tools(grinder and wheels) are the most suitable for a nice surface finish? I will need to remove the primer and the mill scale of the hardox. The goal is to have a finish looking like this: example-2. Do I need to do anything else besides removing primer and mill scale?
Thank you for taking your time and writing a response!
   / preparing metal for electroplating #2
If you don't want to use paint, why use zinc? It's one of the soft metals like copper. It won't last either. If you want shinny, make your tool out of stainless steel. No plating is going to stand up against abrasive soil. That is unless you get into some exotics like titanium or other PVD coatings.
I agree with you about short lifetime of zinc. Either paint or zinc will get abraded away. Its just that if zinc is gone, the implement is hardly visually degraded compared to if paint is gone. That is, if kept in dry place so rust doesn't form quickly. That is my reasoning.
   / preparing metal for electroplating #4
No need for any plating then. Just polish it. If you plan on maintaining it after the zinc is gone, plating is just a waste of time and money. You'll loose the plating on the edge almost immediately.
Typically, items to be plated are polished anyway. If you're obsessed with plating, use nickel. Nickel is what's under chrome and much harder than zinc. On a scale of 1-10, zinc is like toilet paper. 😏
   / preparing metal for electroplating #5
There are several automotive finishes that will be way more durable than a home application of a zinc coating.
POR15 and KBS Rust Seal are moisture cure high solids paints that are like stone when cured. I'd try one of those before plating or any hardware store type paint.
   / preparing metal for electroplating #6
Polish it up till you are happy with it and then clear coat it or electroplate it.
Once you run it in the dirt that part will polish up even more, as soon as you are done take a rattle can and hit it with clear finish. Lacquer works well because it dries fast.
We did that with the plows and rippers, the metal sat there all super shiny till next year. We told the other farmers that it saved on fuel when we first started plowing the next season.
   / preparing metal for electroplating #7
That would work fine if you never painted it. For DIY hobby farmer would have been done already cause I would have sprayed with a bomb I paid 2$ for at Bargain Barn
15 minutes of I was in a hurry
Is the goal to make a tool or endlessly fug with it?
   / preparing metal for electroplating #8
The rattle can approach is what I do on my snow blower B4 storing for the summer.
All bare metal gets a light coating of whatever rattle can is at hand.
My theory is that wet snow will adhere to rusted metal much better than polished metal.
Since I never clogged last winter I guess I proved my theory.
   / preparing metal for electroplating #9
Hello everyone!
To electroplate the metal must be very clean; rust and grease free. Electro plating involves placing the entire attachment in a bath and running a current through the bath and the implement.
Respectfully, it is going to be hard to find a company that can handle a part that big and if they can they will not let you use their bath because one dirty part will corrupt the entire bath. (I worked in a truck plant that elector plated the under carriage of class 8 trucks). Below is a large part plater. I do not know if they will do single runs. I am sure they will have specs on how clean the part has to be before going into their tanks.
Chrome plate is even more temperamental. If the metal under the plate is not hardened the plate will not adhere; it will flake off in very thin layers.
There are companies that specialize in powder coating. Powder coating is durable and environmentally friendly.
   / preparing metal for electroplating #10
I been trying to poke the OP wuith a reality stick a little here. While its great to learn all this and evne talk forum about it millions of hrs put on implements of this nature for decades with no paint on it at all and this would last a liftetime without doing anything let alone electroplationg, zinc and all kinds of stuff. You asked about first time work of this nature and you are a poster child for a pice of scotchbrite and a spray can if you want some fuggin color on it.
When its done and before it rusts up and you can do this to steel like that is spray it with penetrating spray. Spray steel when new like that with it and it rusts to a hard finisn seems to seal it in. As Egon talk about down at that level if it sucks up a little oil before it does water it weathers different and to shiney steel like cultivator and plows when they are really fresh a shot of that stuff slows rust from pits to a whiff over a winter and it scours right back up and even a scuff of scotchbrite in the spring smooths it a little,,, this aint really moon shot science except for playing with the geometry where fine tilt and draft adjustments make all the difference.
Lot of people hook on and dont realize they are not the center of the tool and often needs adjustment even along the way. The finish doesnt mean squat, the finish is good as in the general appearance and people take better care of stuff well painted. Skip all this stuff and buy a couple spray cans as you go, a gallon in a couple colors and some sponge brushed from HF and box of scuff pads. You need a gallon of thinner to clean up and a couple rolls of painter tape and do it.
Here is what happened. I paint up a lot of worn equipment as needed and at overhaul, main service, some events.
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
