Prep & Paint for Jubilee Chasis
   / Prep & Paint for Jubilee Chasis #1
Tractor Ninja
Riverside, CA
Ford Golden Jubilee
So here is the plan, need some collective guidance and wisdom on moving forward.
As a little background, I recently bought a Jubilee and have been working on getting a handle on the overall condition. At some point it was painted yellow and one of the things on the to do list is to return it to the orignal colors. I've got all the sheet metal off, exhaust, gas tank & supports and seat. I still need to remove radiator, wheels and rear fenders. I am planning on having a mobile media/sand blaster visit and remove all the old paint. As for the sheet metal a good friend of mine runs a paint and body shop so he will be working the tin for me.
My question is specifically on how to treat the chasis. Once the tractor has been blasted I know that I will need to get it either undercover or primed immediatly. For ease of changinp parts out and maintenance, I'd like to paint the chasis with spray cans if I can achieve a good end result. What products for primer and the Ford red would you suggest that hopefully come in a spray can? I'm not a total purist so a red that is around the correct Ford red is fine with me. Since this is a used working tractor I'd like to be able to change parts out, fix leaks and get her pretty again with a can or two of paint. If this matters, I live in Riverside California so mostly arid, very little rain, almost no humidity and no snow whatsoever. It will be stored under a tarp.
As for the tin, I am supposed to supply my friend with the paint code for the Ford grey, any thoughts on this also? Thank you!:thumbsup:
   / Prep & Paint for Jubilee Chasis #2
I would NEVER sand blast a fully assembled tractor - Blast media gets EVERYWHERE. Instead, buy 6-8 cans of quality oven cleaner, park it in the shade and spray the oven cleaner (careful it contains lye) and let it sit overnight. Next morning pressure wash the tractor being careful to stay away from bearings, and oil cups. Power wire brush any loose or flaking paint. If it isn't coming off, leave it alone.
Primer is a personal choice - If it makes you feel good, use it. I've had good luck with Rustoleum Rusty Metal Primer. It's tacky even after it dries. FYI, Henry never used primer on his tractors.
Treat any bare or rusted spots with phosphoric acid - Found at Home Depot or Lowe's in the paint section. Here on the right coast, it's called Phosphoric Prep and Etch and is marketed by Klean Strip. Just follow the label directions.
Wash it down with paint thinner before spraying. Blow it off, put on your paint mask and make it pretty.
Rustoleum, Sunrise Red is extremely close to the OEM red. You can brush or roll the paint on the rough castings - Brush strokes won't show up. Any hard to reach areas can be spray canned but you will get better coverage with the roller/brush.
Here are some paint codes for the grey - Ford Paint Code: M 13243, Tisco: TP240, PPG: 32675, Centauri: 250202, Van Sickle: 457
Great advice and I'm betting that 8 cans of oven cleaner will be much cheaper than a media blaster. You make a good point about Henry not priming the tractor before paint, but I'm betting that the extra step may be an enhancement and worth the extra time and expense. Good to hear Rustoleum has an enamel that is close to the Ford red, I've worked with that product before on a trailer and had positive results. I've got to say that there are a lot of nooks and crannies to get at with a roller and brush. How about shooting it out of a paint gun? I'm assuming that would be better coverage than a spray can? I currently don't have a paint gun but would be willing to pick a cheap one up from Harbor Freight for the ordeal.
Good information about the Ford grey, thank you!
   / Prep & Paint for Jubilee Chasis #4
ditto what DB said.
blast media gets everywhere.
as for rattle can paint? get a primer that will be compatible with whatever rattle cab you are using.
not my first choice though. IMHO.. you will pay more $$ in rattle cans than buying a 50$ pancake compressor.. and a 20$ harbor greight air syphon gun, and a quart of greay, 1-2 quarts of red.. and a couple quarts of primer.. IMHO
your call.
in either case.. forget covering after blasting, if you do blast. blasted metal will rust in hours if not treated.. even just by humidity in the air..
   / Prep & Paint for Jubilee Chasis #5
Personally, I like to prime with rattle cans and paint with a spray gun because priming often consists of having to prime many small parts immediately after they have been sandblasted. As mentioned by Sounguy, forget the idea of covering after sandblasting because parts that have been sandblasted will rust within hours if they aren't cleaned and primed almost immediately.
Lastly, I second the advice from Dollar Bill about never sandblasting a whole tractor, because it can and will get into everything.
   / Prep & Paint for Jubilee Chasis #6
you can get little 6 oz touch up guns that let you mix a small amount of primer to paint with. there are also fill your oen bottles that use compressed air.. both would be superior to rattle canning.. though nearly as easy.
   / Prep & Paint for Jubilee Chasis #7
Absolutely, I didn't suggest that as you mentioned spray cans in your original post. You should also add hardener for enhanced durability, just be sure to use a quality respirator.
WOW, good advice and thank you! So no spray cans and I'm fine with that. I have a compressor so seems I'm halfway there. I do not have a spray gun so a recomendation would be appreciated since our local Harbor Freight isn't too helpful. I'll also research hardners.
   / Prep & Paint for Jubilee Chasis #9
The last paint gun I purchased was a Binks # 7 in 1975 so I won't be much help. Still works as good as the day I bought it. You gotta have a quick wrist because it puts out paint like a garden hose.
I'm sure Soundguy will be along shortly to help with a gun selection.
If you have a Tractor Supply nearby, this is what you want for the Rustoleum - I'm away from my receipe until Friday if no one else makes a recommendation, I can get it for you.
Majicョ Catalyst Hardener, 1/2 pint - 1177127 | Tractor Supply Company
   / Prep & Paint for Jubilee Chasis #10
You can get a cheapo hvlp gun online as well as a mask/respirator use a hardner its worth it.
2012 CALICO TRAILER CONTAINMENT TRAILER (A45046)
2012 CALICO...
2016 GENIE GS-2632 ELECTRIC SCISSOR LIFT (A45046)
2016 GENIE GS-2632...
2022 Bobcat E60 Excavator (A42203)
2022 Bobcat E60...
AGT MX12RX Mini Excavator (A44501)
AGT MX12RX Mini...
2013 DRAGON 150BBL ALUMINUM VACUUM TANK TRAILER (A45046)
2013 DRAGON 150BBL...
Fleco 30" 8T Excavator Bucket (A42203)
Fleco 30" 8T...
