Pre season snow blower check
   / Pre season snow blower check #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I was doing a pre-season look at the Kubota B2789 snow blower this afternoon.
One of the impeller blades was binding on the housing. Pessimistic me, was all in a worry about a bent shaft or impeller (4 blade)
I removed the discharge chute thinking to get a pry bar in. But even that top port didn't really give leverage access to the rubbing blade.
Then I got to looking hard at each blade gap to the housing. There was a stone lodged against the back side of the blade OPPOSITE of the blade that was rubbing. It took some real hammer blows on some sheet material used as a drift to get that stone to drop out.
Sure, that stone would have rubbed it's self away in short time, leaving a groove and damage until it did. Or, I would have made a mess of the impeller trying to bend the blade that wasn't at fault.
Sure made me glad to be a "what IS the real problem" kind of mechanic. And the discharge chute has never run more easily! ;-)
Let it SNOW!
   / Pre season snow blower check #2
Good find. I just did a checkup on my blower also, and greased / lubed the drivetrain.
It has sat for the last 5 years without use.
   / Pre season snow blower check #3
Good Morning CalG,
Always a good idea to check out the equipment before the season starts ! Grease , oil change and filter along with general maintenance! Good catch !
New Holland 273 Hay Baler (A49251)
New Holland 273...
2007 Jeep Wrangler Rubicon 4x4 SUV (A48082)
2007 Jeep Wrangler...
2015 Cadillac Escalade SUV (A46684)
2015 Cadillac...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A45678)
2019 INTERNATIONAL...
2024 OTHI Mini Excavator (A46683)
2024 OTHI Mini...
Galvanized Pipe (A49251)
Galvanized Pipe...
