pre air filter?
   / pre air filter? #1
runningbird
Gisela, AZ
yanmar 1110d ,fx28d
hey all
I'm in need of some kind of air filter for my 2000. Our area is so dry that I am constantly sucking dirt. I have already had to replace the rings once and I'm sure it was from dirt. Does anyone have any idea's, I was thinking of some kind of sock that might fit over the intake extension.
anyway thanks for the help.
mark
   / pre air filter? #2
Are you running the proper air filter, and not some "almost fits" supposed match-up? Too many people think the 6022 NAPA is a cross for the original when it is not; it is an "almost fits.". We have an aftermarket made to the same size specs as the original. In your conditions you may need to change it every 50 hours or so. Also make sure the neoprene seals on the bottom and top of your canister are good, as well as the neoprene sleeve at the base of the canister where it enters the intake manifold. If they are not, we have parts.
   / pre air filter? #3
Funny you should mention the almost fits air filter. I replaced it with the OEM filter last week because after studying it a while I noticed that what came in my 2000 "almost fit"...a no-no for air filtration.
   / pre air filter?
well I'm using a filter from Hoye. the dirt and dust is terrible. and yes I change that filter regular.
mark
   / pre air filter? #5
mark
I'm confused. Are you saying the filter you are using is not working?
   / pre air filter?
I am saying that it is not working well enough for me. I do change it on a regular basis. with that intake tube hanging so low it is just sucking up the dirt. it does not seem like I should need to change filters so quickley. but I have had to. and the conditions are extreme over hear in the south west.
mark
   / pre air filter? #7
runningbird said:
hey all
mark
I have a YM2000B, don't have that problem, or any real answer. Of course I am not in Az either. I would try taping one of those human drugstore pollution masks to the intake tube. If they work for people they should work for a tractor. Buy them by the pack and keep on board if they work.
   / pre air filter?
Now that's a good idea about the mask. I work at a hospital so it won't be a problem getting mask.
thanks so much. I'll give it a try.
mark
   / pre air filter? #9
70's V8 Jeeps (AMC) had a foam ring wrapped around the normal paper air filter. The instructions said something like take it off and blow it out daily in heavy dust conditions plus wash it frequently. I don't recall if it was oiled.
I think I would start with something like that.
First choice would be a foam ring designed for this. Second choice would be to make the ring out of home A/C return-air filter material.
I think you need the larger surface area of something that wraps around the paper filter, compared to putting a small filter over the end of that intake hose.
Another alternative would be to install a proper tractor pre-filter off some other model.
   / pre air filter?
well that was what I was hoping for, some kind of pre filter. I just don't know where to start my search.
thanks
mark
Caterpillar 200 Forklift (A53117)
Caterpillar 200...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
1839 (A51248)
1839 (A51248)
2005 Nissan Titan (A50121)
2005 Nissan Titan...
T3 Motion Patroller Segway (A51694)
T3 Motion...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
