Pre 50 Hour Service Benefit
   / Pre 50 Hour Service Benefit #1
keving
Virginia/WV
Kubota 7040HDC
Is there any downside to doing the 50 hour service at say 35 hours? I'm switching to Amsoil on everything. Appreciate your input!
   / Pre 50 Hour Service Benefit #2
I think the proper break in period is important although at 35 hours you could certainly change it. I use amsoil as well but I waited until the first 50 hours to ensure proper break in and mating of the parts. Not sure how much it really matters but I try to do as the manual says in this regard.
   / Pre 50 Hour Service Benefit #3
Amsoil is synthetic oil. You should wait until the piston rings seat-in before going with synthetic oils. Personally, I would wait till about 300-500 hrs until I put synthetic oil in my diesel tractor engine.
Also, unless you are doing extended drain intervals with Amsoil, you might be waisting your money, of course an Amsoil salesman would disagree with me.
Im not bashing Amsoil, just trying to help you think it through.
OBTW, if you live in very cold weather, synthetic oil is fabulous on those cold starts and that is why some of my engines use synthetic oil.
I'm curious why luxury and performance car manufacturers ship their cars with synthetic oil from the factory. The Corvette, for example, comes with Mobil 1 right from the factory. What impact does the synthetic oil have on the break in procedure for this car? Does a diesel differ?
   / Pre 50 Hour Service Benefit #5
   / Pre 50 Hour Service Benefit #6
This is an 'old wive's tale'. Synthetic oil can be`used from the first oil change.
For some of us, that'd be 3 - 5 years! :eek:
   / Pre 50 Hour Service Benefit #7
:eek:
Mike my dealer told me that the piston rings are seated within the 1st 50 hours. If that is the case aren't you saying the same thing? I waited until about 60 hours then changed the oil & filter and have been with synthetic oil ever since. I would not however have gone to synthetic before the 1st 50 hour interval.
   / Pre 50 Hour Service Benefit #8
I agree. That's why I mentioned it's OK to use synthetic oil from the first oil change. :)
   / Pre 50 Hour Service Benefit #9
The question I was adressing: Can dino oil be changed with synthetic oil before the 50 hr interval?
Sure, if the rings are seated-in to your satisfaction, then I wouldnt see a problem with it. So if the dealer says that the rings are seated-in at 35 hrs, then you are ready for synthetic. If you wanted to be scientific about it, you should have checked combustion chamber pressures at the beginning and then when the pressures stabilized you would know that the rings are seated. Most of us just watch the oil consumption and make conclusions on engine ring condition based on that, at least that is what I do. I fill the crankcase to exactly the dot on my dipstick and carefully monitor oil consumption. Diesels do burn a little oil and that is normal. Expect that the break period will show slightly more oil consumption. You get the idea...
But anyway, my question is why would anyone spend the money on syn oil during the breakin period? Wive's tail or not, it seems foolish to use syn oil during breakin period, if you dont have to, because it seems like a waste of money. Just use dino oil for 50 hrs, then switch to syn oil and stay with syn.
I also said, that I would personally wait 300-500 hrs before I switched to synthetic oil. The reason I said that is because I wanted to be able to compare my tractor performance, dino oils vs synthetic oil.
In other words, I wanted to be able to get a better feel for whether the syn oil was improving my performance.
Finally, I do think that syn oils are great, esp for cold weather starting and extreme high temps AND if you want extended drain intervals. If you use syn oil for other reasons it seems unlikely you could actually ever recover the costs. One poster mentioned he was a low hour/yr user, so it seems even more difficult to cost justify. Maybe someone could show me the numbers, if Im mistaken.
I use Mobil one in most of my engines, i.e. auto, and small engines, except my four wheeler (because it shares engine oil w/ clutch and honda says dont do it). I really like the syn oils, especially on air cooled engines, but Im just waiting a little while to use it on my tractor.
OBTW, I put 490 hrs on my CUT in two years. My dealer says that is more hrs than most CUT users. Maybe, I dont know...
Next oil change I plan on switching to Mobil Delvac 1. We'll see if I can tell a difference in cold weather starting and warmup times.
One last thought. I suggest using same BRAND of oil when switching from dino oil to synethic. For example, I use Mobil Delvac 1300 now, but will switch to Mobil Delvac 1. This way you get the same additive package. To the best of my knowledge, Amsoil doesnt supply a dino oil, so going to Amsoil right away, is probably a good idea. But then you dont go to the local Farm and Home store and get your Amsoil. I believe it is sold in a multi-level marketing way, like Amway maybe? I wonder, is it the same company?
Maybe someone could help me on that one. Ive never seen Amsoil on store shelves, to the best of my knowledge and that is why Im not a user of it. I do think the specs on Amsoil is better than Mobil, tho. So you'll have a good product, I you dont mind hunting for a Amsoil dealer...
dwight
   / Pre 50 Hour Service Benefit #10
What's so good about synthetic oil versus standard oil in a tractor? I've never used synthetic before or done any research on it.
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
MAHINDRA 2810 TRACTOR (A54756)
MAHINDRA 2810...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2001 Acura MDX SUV (A53424)
2001 Acura MDX SUV...
