Powerpack for tipping Trailer
   / Powerpack for tipping Trailer #1
Rgillard
Ireland
Fiat 82-94
Hello,
Was looking up the surplus centre website and seen this 12VDC Powerpack. It says that it will operate a double acting cylinder. I am just wondering does this mean that it has the directional control valves included in it. So if i bought one of the powerpacks and connected it directly to my doulbe acting cylinder could I control its extention and retraction. I want to use it to build a tipping trailer for my ATV and it would leave the hydraulics nice and tidy and it would be electrically controlled rather than having manual valves. Can someone just verify my thoughts or tell me I'm reading it wrong.
http://www.surpluscenter.com/item.asp?UID=2006071307063584&item=9-7187&catname=hydraulic
Regards,
Ronan
   / Powerpack for tipping Trailer #2
I'm not familiar with that particuliar model but the ones I've seen that operate a double action cylinder do it simply by reversing the direction of the motor. No external valve required.
   / Powerpack for tipping Trailer #3
That unit looks like it will do what you want and, from the description, works as jmc described, "by reversing the direction of the motor". Note, that my dump trailer uses a single acting cylinder with appropriate pump. Just uses gravity to go down. If you don't need the down pressure, you might find a cheaper unit and use your cylinder as single action.
I actually have a single acting cylinder quite similar in size to my double acting cylinder. I was not really sure what sort of weight in the trailer body was needed to return the cylinder by gravity. This is because the trailer I am making is quite small in respect to the ones being built by you guys. Will the cylinder return to its retracted position even if the trailer body is light when empty? If so there is no point wasting a double acting cylinder.
Does the pump just pump the oil into the ram directly and there is a pressure relief valve that triggers when it reaches its end point. When dropping the trailer body is there some solenoid valve that opens to let the oil return to the resevoir or how is the cylinder retracted? Can the cylinder be held at say 50% stroke with this set up? Sounds like it is the most simple approach to the build anyway. You guys dont know how lucky you are with that surplus centre. Stuff is so cheap. Is there anyone here from the Uk that knows of a place similar to the surplus centre as to ship something like that powerpack from the states is about $250.
   / Powerpack for tipping Trailer #5
I honestly don't know how much weight it takes. Mines dam heavy.
Yes.
Yes.
Yes. And I think the unit said it had double piloted check valves which should hold any position for a year or so.
Well, I for one, feel lucky and am thankful every day for living in the USA for an awful lot of reasons :D
   / Powerpack for tipping Trailer #6
Here's an address for a supplier in the UK:
http://www.hydraproducts.co.uk/hydraulic-power-packs.htm (I can't post a link ever since they changed this site)
These units can draw some serious amperage, depending on flow rate and required pressure. Are you going to have a separate car battery or try to use the little ATV battery?
Another factor may be when you dump a heavy load, it could lift the back of your ATV when the load shifts behind the axle. Sorry if you've already considered these things.
John
I plan to use a 12V battery that is separate from the ATV. I don't intend on hauling very heavy dirt around. A lot of this project is for my own learning about hydraulics and it would be so cool to have a tipping trailer. Plan to maybe hook it up on the tractor lawnmower to give more grass capacity. Comtacted that crowd in the UK 182 pounds plus VAT for the double acting pump. Thanks for the help
   / Powerpack for tipping Trailer #8
If yuo are worried about gravity down.. buy a large spring.. like a trampoline uses.. attach it so that it is in a bit of tension whent he cyl is colapsed.. and in much tension when cyl is extended... the extra 30-40# or pressure needed to overcome the spring will be nothing for those portable hyd power units.. yet when yuo trip the pressure release.. that will be a positive force helping retract the cyl..
Soundguy
   / Powerpack for tipping Trailer #9
Keep in mind that if your cylinder needs more than .75 gallons of oil to fully extend it then you have a problem. Otherwise the pump looks like it's good to go.
   / Powerpack for tipping Trailer #10
He can always run it out and add tot he tank to get the lines filled.. then it is just the volume of the cylinder to deal with.. But yes.. if the cylinder volume exceds that.. then you can't extend her any more.. etc. ( better he choses a cyl to fit those specs..etc.... or choses a similar unit with higher specs.. etc.. )
Soundguy
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
2021 John Deere RD40F Draper Head (A53342)
2021 John Deere...
2011 JOHN DEERE 6115D (A52472)
2011 JOHN DEERE...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2017 FORD F350 (INOPERABLE) (A52472)
2017 FORD F350...
