Mowing powered flailed cutter
   / powered flailed cutter #1
Kevpat
Isle of Wight
Husqvarna
GeoTech Pro GTFM 120 LE tow behind flail mower
I am thinking of buying the above item to tow behind my Husqvarna tractor mower as the Husq. quickly clogs up when the grass is longer than 6" and is wet or even just damp.
Will the Geo Tech cope with long wet grass ?
   / powered flailed cutter #2
I would think it should handle up to 12” deep grass on high throttle if you go slow.
Many thanks. My paddock is also rather uneven ...would that be a problem for the GeoTech 120 ?
   / powered flailed cutter #4
No problem at all. The nice thing about flail mowers is that you can run over just about anything. Plus it won稚 pitch big rocks. It might throw gravel a little.
I mow with a 73 flail. The blades aren稚 particularly sharp, but it handles waist deep grass on my 41hp without trouble.
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
JCB 3TS 8T SKID STEER (A51242)
JCB 3TS 8T SKID...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
Walking Floor Trailer (A50322)
Walking Floor...
Diamond 5' Heavy Duty Excavator Mower (LIKE NEW) (A50774)
Diamond 5' Heavy...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
