Powerbook External Antenna
   / Powerbook External Antenna #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
My wife has an older G4 Powerbook (aluminum cover) that does not pick up our wifi signal strongly because the cover blocks/impedes the signal..
I was looking on ebay and did a search for 'wifi usb antenna' and found what looks like a few external antennas that will work on the Mac.. One is called a 'high gain WLAN USB adapter with antenna' - its a usb device that you can add an external antenna to.
Im a little confused though 1) does this replace the aircard in the computer or does it just help boost the signal strength
any other suggestions on how to boost the signal strength? I already added a bigger antenna to the router, but the computer still doesnt get a very strong signal
Brian
   / Powerbook External Antenna #2
I use this type of antenna on my PC and has much better range than the built in Wi-FI. It replaces the built-in Wi-Fi. I turn off operation of the built in Wi-Fi when using it.
2013 BMW 528i (A53424)
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2008 MARIAH SKI BOAT (A54756)
2008 MARIAH SKI...
2009 MULTIQUIP 25KW GENERATOR (A53843)
2009 MULTIQUIP...
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
