Power
   / Power #1
ChasK
Indiana
Kioti CK20
Is it normal to lose a lot of power when executing a sharp turn....it seems like when the power steering pump really cranks (on a very tight turn) it saps a lot of power from not only the wheels, but the PTO as well.
Any thoughts?
ChasK
   / Power #2
Depends a lot on what RPM you have set. Higher RPM will result in a much lower response to this. It is normal and is caused my turning your wheel completely to one side or the other. My owner's manual even addresses this, and says not to keep the wheels in this position for long. I try to turn just to before where the effect happes. It's all about the hydraulics, and not a problem unless you turn full and keep it that way. Remember, it's more pronounced at lower RPM. John
   / Power #3
ChasK
There is a TSB on the CK20's about the power steering relief pressure adjustment. It is set to high and when you turn the wheels left or right you will have power loss. Your dealer should know about this , TSB # 032904 . We have generally seen the pressure set around 1800 psi and it should be set at 1560 psi. Takes about an hour or so to adjust.
   / Power #4
</font><font color="blue" class="small">( There is a TSB on the CK20's about the power steering relief pressure adjustment. It is set to high and when you turn the wheels left or right you will have power loss. )</font>
Maybe what I'm talking about isn't the same reaction as ChasK is having? On mine is doesn't seem to be any problem unless I'm at really low RPM and only if I keep it turned tight. Should I have this adjusted? John
   / Power #5
John
Ya I would atleast get it checked. All the ones I have checked are running about 1800 psi. All the new CK20s that have a SN# that start with a D are not affected by this.
   / Power #6
</font><font color="blue" class="small">( Ya I would atleast get it checked. All the ones I have checked are running about 1800 psi. All the new CK20s that have a SN# that start with a D are not affected by this.
)</font>
Thanks Jon. My serial number has no alphas, 3196-00571.
I'll have it checked. John
   / Power #7
i'm 3196-00013...guess i'll need to get that checked too...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52128)
Chevrolet C8500...
2004 GREAT DANE 53FT REEFER TRAILER (A52141)
2004 GREAT DANE...
UNUSED AGT ATK-B1000 CARLIFT (A51244)
UNUSED AGT...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
