Power Trac's Attitude Toward Modifications
   / Power Trac's Attitude Toward Modifications #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I was just wondering what people have heard from Power Trac representatives about people modifying their machines. My personnel experience from someone at PT (I am not sure who), was that they have seen people make a lot of changes. The comment was that some machines do not even look like PT's anymore. I was wondering what others had heard. Also let's have a little contest about who has made the biggest change to the appearance of their machine. No prize, just a congradulations.
So, let's discuss PT's attitude and pictures of your much modified machine. Maybe we need two awards, one for the most appearance change and one for the most change by function.
An additional comment. The warranty where PT sends you parts and you return the old one and they rarely look at the machine eliminates much of the normal discouragement of modifying a machine while it is under warranty. Of course if you had to take it back they would see your changes.
I had a situation where one of the bolts on the quick attach front plate that holds the plate locking dogs on (you know, the ones that are essentially studs going thrugh the plate and them welded to the plate on the front side) came loose. I called up PT and they said I could have somebody weld it back, and if that did not work I could send it to them and they would fix it. I felt this was a very open attitude toward self repair. I did not have a welder at that point, but this kinda got me going in that direction. Since then I have had to weld the other bolt. This was not an easy weld to make and cannot be very thick or it interfers with the attachment. It took several attempts and I had to grind grooves in the bolt holes to get enough surface area to hold.
   / Power Trac's Attitude Toward Modifications #3
When I first got my 1845, I cut off the pin hitch in back and welded a 2" receiver (the whole hitch from a '78 Cadillac) across the back. PTs reaction to the picture I posted on TBN: "That looks as if it will work pretty well."
It's one of the reasons I like Power Trac. They'll tell you if they don't think something will work, but if you make a change that helps you do the jobs you have, they are happy that the machine suits your jobs even better. Not many manufacturers are like that.
I remember that, but I can't seem to see your picture. Anyone know why?
   / Power Trac's Attitude Toward Modifications #6
I haven't heard anything from them because they don't contact me and I don't contact them unless I need parts. :)
My machine is approaching 5 years old and I have no problems with modifying it now that it is out of warranty. I fully understand why any company would not approve modifications when in warranty and would never "officially" condone modification of their product... it opens up a whole can of legal worms.
The machines made by Power Trac are just begging to be modified. Look at them:
Solid, thick plate steel.
Simple design.
No fancy lines or curves to mess up.
Just a raw machine waiting to live up to its potential and that potential is whatever you want it to be. They are a tinkerer's dream come true. Now where's my torch and welder??? :D
   / Power Trac's Attitude Toward Modifications #7
One other thought....
I'm waiting for someone to weld the articulation joint solid, split the steering and add tracks... who's gonna be first?:eek:
   / Power Trac's Attitude Toward Modifications #8
I had planned that for yesterday afternoon, but I had to work 15 minutes late.
Simple design.
Those do encourage changes. Also the hydraulics makes it relatively easy to change the drive, PTO, steering, lift, etc. systems.
ECHO PE-225 GAS WEED EATER (A51248)
ECHO PE-225 GAS...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A53472)
NEW 2022 Load...
HUTCH TANDEM AXLE (A51247)
HUTCH TANDEM AXLE...
LATE MODEL JOHN DEERE EQ. AUCTION LOT IDENTIFIER 1 (A53084)
LATE MODEL JOHN...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
Scaffolding (A52377)
