Mowing Power-Trac Slope Mower questions
   / Power-Trac Slope Mower questions #1
ToolcatWonka5610
Mount Morris, Michigan
Okay, I've been skimming through the Slope Mower threads and posts and I do have a few questions.
I've heard a lot of overheating problems for these machines. Advice?
Are there any 1845 or 1850 owners in here Michigan?
Does anyone have a link to the Cab for the TSM machines? The one on this forum expired or the "page cannot be found" or something.
   / Power-Trac Slope Mower questions #2
Some machines handle clogging better than others (Clogging by the debris in the air). I think if you were to use an 1845 or 1850 for a large scale mowing operation (all day, every day and unsupervised), you would want to make sure either you had made some mods on the PT, either in the form of a reversible fan or screens or secondary engine oil cooler but for most applications just attention to the guages and a daily cleaning ritual will be all that you need.
If you read about other tractors, you will find this a common issue on a lot of them. Mowing is a dusty dirty job and seldom do designers seem to understand that. Having the mower out front does not help the dust and dirt issue, but I love it being there over being attached to the back.
There are a few cheap / free mods to the PT that can greatly help in dusty conditions.
I do not know of any advantage of the 1845 over the 1850 or visa versa. I will say that the 1850 has tons of guts, and it is pretty strong for the lift arms provided (meaning you can damage the tractor or implements if you are not careful). The tractor will go places you will not.
PT has a fit and finish issue that applies to all tractors. The Deutz is a rock solid engine, so generally not your problem spot.
As for oil leaks, there should not be any, but as we have said, the PT has some fit and finish issues that will leave you pondering why chinese brands are considered worse. But generally simple to fix.
Altavista had some serious issues with his PT. I am not sure if he kept it or sold it or just scrapped it. But when it was working for him he loved it, more than he loved his other machines.
As for the cab, that was the first time I had seen something like that. Not sure how that worked on that tractor as the cab is placed over the articulation, and the AC must have structurally adjusted the overhead.
I guess it is nice to have, but I have never felt the need for it. I would tell your dad to suck it up ;-)
The cab was just a consideration. Summer here in Michigan are really Hot and VERY humid.
For winter use it'd be very good. Winters here are ****! It'd be good to have.
The overheating problem, I don't know if we'd be bushhoging. So far just regular mowing.
The only reason were looking into the 1845 is for it's slope mowing capabilities. We mow on some hills (30+ degrees) but not always. We like the 1850 but as you said "its a large machine for the lift arms provided" thats one reason we like the 1845, less power. I know if we get an 1850 me or my Dad will push it too far. It sounds like the 1845 can be pushed but not as bad as an 1850. For one don't need 65HP diesel. 45HP is good.
Rather than making a new thread, I'm opening an old one.
We talked to the new owners of the property with the 40+ Degree hill. So now I guess we do need a Slope Mower (see our needs are always changing, thats why were jumping back and fourth betwwen models, be this should be the definite machine). So me and my Dad had a long talk last night. He feels the 1850 will be a lot better over the 1845 and it's only $1,000 more plus 20 more Horsepower and an almost 2 foot wider cut. As for attachments, We're sure we'll need these attachments; 90" Mower, Post Driver, Power Rake, Tiller, Mini-Hoe, and Stump Cutter. Now I have some questions;
1). Were getting a Post Driver, any experience with one? (Ponytug and Charile Iliff have one)
2). Also anyone use the Concrete Breaker foot on the Post Driver?
3). Do you run the Post Driver by just flipping the PTO switch and it starts pounding or do you have to individually move the auxilary hydraulic lever up and down?
4). I saw this on a video of MossRoad's 425, does the QA run of the hydraulic PTO so when you put like a Mower on, do you have to unhook the QA lines to attach a hyraulic powered attachment? It looked that way on the video.
Any advice, please give!
   / Power-Trac Slope Mower questions #5
Go with the 1850, I don't think you will regret the HP & you can always throttle down.
The Post Driver hooks up to everything, PTO IN & OUT, Q/A, and the drain line. First you set plumb from the tractor seat, then you square it up L/R with Q/A, then you set the parking brake, turn on the PTO, and stand next to the driver to operate the drive lever. Opening the drive lever raises the dead weight, and releasing the lever drops the weight. While Terry says that you can't lower the weight without driving a post, you can crack the valve and ease it down, but by default the valve lifts, and the moment it is released the weight comes dropping down- So watch out for fingers and toes. Basically, you are raising a 6-800lb weight up and dropping it on the post.
It is really important that you square up the driver, or you will get an out of square post. (As Homer Simpson says "Doh!") It is not hard, but do take a level out with you.
I use a heavy duty bungee cord to hold the post against the driver, with the hooks in front to roll along the post. It helps keep the post from shifting, and it keeps my hands well away from the post while driving. The only downside to the driver is that when people see how easy it is, they will want you to do lots. (So don't let your customer's see you operate it!) :)
If you are planning on do a lot of landscaping, you might want to consider a laser control on the power rake. It will get you to level or to grade rapidly.
Many attachments don't require the use of the Q/A hydraulics.
Have fun,
Peter
...We're sure we'll need these attachments; 90" Mower, Post Driver, Power Rake, Tiller, Mini-Hoe, and Stump Cutter. Now I have some questions;
   / Power-Trac Slope Mower questions #6
Have fun,
Peter
I agree. I have the 1845. I think the 1850 will handle the post driver a little better, since it does tend to bounce the machine a little. If you have a pretty good eyeball, you can run a lot of fence in a hurry, even without a level, but it will be a bit wavy. Getting the base of the post in the right place and getting it vertical does take some care, but it is worth the care. If you just want to hurry, in soft ground like ours you actually can put in 15-20 posts per hour, and they will be much firmer than ones set in holes and tamped.
   / Power-Trac Slope Mower questions #7
ToolcatWonka5610
Are you being serious about all this equipment, or are you just dreaming? Things don't just seem to add up. Do you and your dad have the contracts to support this kind of purchase in todays market? I don't think I would want my kids getting on the Internet making statements and such. I almost think you are just playing with us. No disrespect intended, but if you have cash, cash talks. Is it even legal for you at your age to operate this kind of equipment in a commercial environment. How about Workman's comp insurance for you, do they know your age. How about liability insurance. Like I said before, things just don't add up. How about a trailer for all this.
PT-1850---------------32,000
90" mower--------------4,500
POST DRIVER-----------4,000
POWER RAKE-----------3.000
TILLER-----------------2,400
MINI-HOE--------------2,300
STUMP GRINDER--------2,400
TOTAL----------------48,000
ADD BUCKET/GRAPPLE--2,500
   / Power-Trac Slope Mower questions #8
ToolcatWonka5610
Very well said and to the point !!!.If my Workman's Comp carrier & Liability carrier ever found out I was allowing a 14 year old kid to operate equipment like this for Commercial and /or Residential contracts ...they would drop me like a lead balloon. I agree that a lot of what this young Lad has said just doesn't add up. I will be very surprised if any PT and / or equipment will ever be purchased !!. :rolleyes:
   / Power-Trac Slope Mower questions #9
I must agree with the above post by JJ & Rivco. I have a business & my insurance policy has a standard clause (this covers all 50 states) that probhits any minor under 18 to operate any equipment that is deemed commerical use. In additional an operator of such equipment must rec'd training from a authorized rep.
Now I know each state's workmans comp is different but insurance is basically standard
If I was a client & found a minor was operating such equipment. I would terminate the contract & may notify OHSA.
Guys, I'm taken care of but thats really my own business, not to be rude ;)
I'm actually a bit offended. This is not a dream and I'm not messing with you guys. I work hard in school and on the job. I don't really like the fact that just because I'm a kid doesn't mean I'm playing and all that other stuff :mad: And Rivco, we want a PT to replace all our bigger machines that are too big for our work (but a PT is just right:D) and get ready for a surprise, too, Rivco. But I come one here to get advice about Power Tracs. The only reason I'm on here instead of my dad is he doesn't have a a computer and internet (even though he could easily afford one) and he doesn't really like computers anyway. And yes we do have enough jobs to support and afford a PT-1850. But were still trying to find a decent used Slope Mower for a good deal and one that we can go see.
I'm sorry guys, not trying be mean here, I've been under a lot of stress lately (work, school, my grades,the end of the year exams, planning the trip to Tazewell) Sorry again I just wanted to get that off my chest and straighten things out ;)
Now let's put this behind us and get back to Power Tracs :cool:
Anyone happen to have a picture of the Concrete Breaker Foot for the Post Driver? :confused:
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
Saxon Tri Wing Finish Mower (A52384)
Saxon Tri Wing...
JOHN DEERE 6180CI510 LOT NUMBER 244 (A53084)
JOHN DEERE...
1994 Fontaine 48 ft. T/A Float Trailer (A53117)
1994 Fontaine 48...
2011 GMC Savana 10FT Box Van (A51692)
2011 GMC Savana...
2012 Tiger 130BBL Vacuum Trailer (A53117)
2012 Tiger 130BBL...
