lhfarm
Veteran Member
When I was using my BH to find the water line to the old barn so I could have water in my new barn, I snagged and broke both the water line and power cable (10/2 w/o ground). I got the water line run in and thought I'd drop a power line in the trench to the new barn while I was at it. I am going to run a new service line to the barn, but thought it would be handy to have another power source for now.
I wired up an outlet, and using my volt/ohm meter, have a reading 122v. Plugged in a small drill and nothing. I didn't have a test lamp, but with the VM plugged into one socket and the drill in the second, pulling the drill trigger causes the volts to drop to nothing. /forums/images/graemlins/confused.gif
Is it possible that I damaged the cable in more than one place when I snagged it? Are there some tests I can run to check the wire? Any advice appreciated. Thanks,
