power take off
   / power take off #1
stuart greig
gravely 810
I have a gravely 810 when i ingaged the power take off the mower blades turned slowley iwas told to ajust the lever rod to1 inch now the blades turn at the right speed but i have to hold the lever when ilet go the blades slowely stop turning could someone help thank you
   / power take off #3
Adjusting the PTO clutch is a bit of a tricky job on the 800/8000 series. Two turns too much on the clevis is enough to have it misadjusted. What you want is a little free play when the clutch is fully engaged. From your description, you have too much free play now. You had too little before. Hope this helps.
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
2020 CATERPILLAR 299D3XE SKID STEER (A52705)
2020 CATERPILLAR...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
UNUSED GAS CADDY (A54757)
UNUSED GAS CADDY...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
2006 TerraGator 8104 (A55301)
2006 TerraGator...
