Power Stering noise
   / Power Stering noise #1
JD 4520
Platinum Member
Snohomish County WA
John Deere 4520
On my 4520, I get what seems to be a slight squeak in what seems to be the power steering only when I turn the steering wheel to the right. I don't get the noise when I turn the wheel to the left and it dissipates as soon as I hold the position still and don't continue to turn. Any idea what it is or what to do to correct it?
   / Power Stering noise #2
any foam or water emulsion in the resevoir?
is there a filter in the system?
cleaned recently?
resevoir full?
I will check these point out. I presume the power steering is a separate system and not part of the hydraulic system. I have not otherwise serviced the power steering.
   / Power Stering noise #4
Do a search here on this subject. This has been reported on before. I think it's more of a noise in a bushing or something on the steering column than it is something in the PS hydraulic system. I have a similar noise in my 4520. I told the dealer to check it out last year when it was in the shop to replace the water pump and they said that they couldn't hear it. Obviously they had the stereo too loud in the cab.
-Dave
1983 Case 580D (A47477)
1983 Case 580D...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
