Power steering
   / Power steering #1
fermidable
Dunham, Quebec, Canada
Kubota L-2800
Hi, I have an old John Deer 300 small tractor. It is equipped with hydraulic plugs. It is equipped with a front loader. BUT there is no power Steering and it is almost impossible to drive the tractor as the weight is very heavy. I have to install a power steering. I have found an electric power steering coming from a Saturn Vue but I think that it is too big to be installed on this small tractor. I have also found a boat hydraulic system and this should be easier to install, but is it strong enough to do the job properly? So I am a bit lost in all that....any suggestions? or recommendations,
   / Power steering #2
JD utility tractor power steering valve can be added to a model 300. Be sure if getting used valve get a closed center style unit. Can you post a close up of RH side of tractor showing current steering housing?
7022 (A50322)
7022 (A50322)
2012 BMW 328i Sedan (A50324)
2012 BMW 328i...
2016 John Deere 6155M (A50120)
2016 John Deere...
Swict 72" Bucket (A50121)
Swict 72" Bucket...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
INSPECTION (A51573)
INSPECTION (A51573)
