Power steering uses hydraulic fluid?
   / Power steering uses hydraulic fluid? #1
Gray Hand
Kubota M4050
thanks for the diagram. Again for the 1985 kubot M4050; the owners manual says the place to check the power steering fluid is on the left side under the hood. Can't find anything that even resembles a power steering reservoir. Online it says the power steering uses the hydraulic fluid. Anyone out there have a M4050 and can verify this.
   / Power steering uses hydraulic fluid? #2
Workmaster 50 is the same. Looking at front, raise hood (workmaster) and it is near radiator reservoir. Radiator fluid is green (workmaster) and hydralic power steering reservoir is reddish (workmaster). See what color your hydraulic oil is and find reservoir under hood in front of motor that matches. A finger in reservoir will also tell antifreeze liquid or hydraulic fluid. Workmaster 50 uses engine oil, antifreeze for radiator and everything else is hydraulic fluid.
   / Power steering uses hydraulic fluid? #3
Follow the lines up from the hydraulic steering cylinder that operates the steering link. At the other end of these lines will be whatever pump serves that function.
2019 KENWORTH W900 DAYCAB (A45046)
2019 KENWORTH W900...
New/Unused Pallet Forks (A44391)
New/Unused Pallet...
2008 Ford F-150 Pickup Truck, VIN # 1FTPW04598KC49674 (A44391)
2008 Ford F-150...
YANMAR VIO27-5B (INOPERABLE) (A45333)
YANMAR VIO27-5B...
Palfinger PSC 4016 4,000lb Service Crane (A44571)
Palfinger PSC 4016...
2016 Ford F-350 4x4 Pickup Truck (Diesel), VIN # 1FT8W3BT4GEC38506 (A44391)
2016 Ford F-350...
