Power steering question.
   / Power steering question. #1
JDEO
Williamsburg, IA
Branson 3820
I've got a 3820 and I have had a leak from the steering valve assembly. At first I thought it was from the o rings on the hose ends. After digging in to it, it seems to be coming from the top or the seals at the steering shaft.
It doesn't leak much just if I over turn to the stops. My concern is how do I check the level of the PS fluid. Is this tied to the rest of the hydraulic fluid? I see three connections on the gear pump but no stick or fill cap. Am I on the right track? Thanks in advance.
I have the 99b version that has 2 other connections to the box. But no reservoir that I can see. I didn't see the connection on the right. I will have to see if I can track that hose back.
   / Power steering question. #4
If yours is like my 3510i, the "suction hose" is on top and has 2 pump suction inlets - "T"'d together into one common suction line, about 1" or so in diameter that goes down under and back to the tractor sump. The pump output goes out the bottom, I think the front part is the main hydraulic section and the rear section is for power steering.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53473)
Ditch Witch 6510A...
2010 Autocar Xpeditor T/A Labrie Side Loader Garbage Truck (A51692)
2010 Autocar...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53473)
Neckover GL24-2-7K...
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
