Power steering problems
   / Power steering problems #1
Wenal
Chamberlain 306
Hi, I have a chamberlain 306 tractor which we just purchased, my question is when idling the power steering is hard to turn and turns to the left a little easer than to the right, when engine revs up a little the steering gets better does Anyone one have any ideas why please
   / Power steering problems #2
Hi Wenal,
It may be a leakage issue. A steering valve assembly has six big O-rings that are utilised to seal the outside. It's possible that one or more of these huge O-rings are leaking. The power steering housing can be replaced to correct this. After removing the steering wheel, you'll screw on the steering shaft in a clockwise direction. At this point, make sure both valve bodies are out of the housing and in good condition. This replacement procedure should resolve the issue. However, if it does not, the condition may be more serious. This could indicate that one or more of the construction's valves have failed.
2016 CIMC 40FT CONTAINER CHASSIS (A52141)
2016 CIMC 40FT...
Super Star Smithco (A50324)
Super Star Smithco...
71057 (A49346)
71057 (A49346)
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
RoGator RG1100C (A52128)
RoGator RG1100C...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
