power steering lines take a look (4035)
   / power steering lines take a look (4035) #1
jjlite
Bronze Member
U.P. MICHIGAN
mahindra 4035
something that I have found on my tractor, the routing on power steering lines take them right by the pulley on the crank shaft so close that the weight on the pulley was rubbing on the spring wrap on the line! I was in shock when I found it even worse when I realized that the only anchor holding it away from being ripped to pieces was one zip tie. Just thought I would share so people could take a look at there own and maybe keep some blood pressure in check:D
   / power steering lines take a look (4035) #2
Thanks for the heads up..!!!! I checked my 5035, which may have a little different layout, and I had about 2.5" clearance between the lines and the pulley. I did put a big black zip tie on it right after I got it, and left the white zip tie there, too... :)
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50322)
2018 Taylor-Dunn...
Tradewinds Power Unit (A50121)
Tradewinds Power...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
1999 Mack MaxiCruise CH613 (A50120)
1999 Mack...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
