power steering fluid leak
   / power steering fluid leak #1
Hunt4fun
Missouri
Mahindra 6500 4WD
I have a very small amount of power steering fluid leaking around the hose clamp. has anyone else had this problem? My tractor is pretty new, about one month and has only 38 hrs on it so far.
   / power steering fluid leak #2
We have a 6520 with 75.5 Hours and a similar problem a very slow seep where the hard line connects to the rubber line going into the pump, just tightened the clamp, cleaned the area out and have had no problem since. Have noticed an oil leak will need to look into that before the weekend.
exactly where my leak is. It corrected with a little tightening.
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2015 Clarke Power Gen 47KW (A50324)
2015 Clarke Power...
80in HD Tooth...
